Question about Sony Handycam DCR-TRV250E Digital Camcorder
Sony digiital handycam dcr-trv250
When a tape is inserted and the unit is powered on , whether in vcr or camera mode a beeps and displays a flashing arrow
It will not fast fwd , rew , or record , also displays c:31:23
  • 3 more comments
  • proveal Oct 29, 2008
    but the reels work fine when loading the tape , it initializes by forwarding or rew not sure but they do work then
    thank you I guess thye were not built to last
  • Alexisblay Nov 02, 2008
    I have the same problem. But the reels do not seem to be turning. Is it worth fixing?
  • Any Guy
    Any Guy May 11, 2010
    If the reels appear to be turning, then the actual reel sensors or the flex cable that is part of the loading chassis have likely failed. Either way, it's not an easy repair and best left to a qualified technician
  • Any Guy
    The error you are looking at is a reel error, meaning the the tape reels are not turning. The likely causes are a defective tape, bent reel tables or other drive problems
  • 320 Answers
You are probably looking at around $100 repair to get the mech sub chassis, with the reel sensors replaced. Please, if you approve of my information, please be sure to rate it. Thanks!
Posted on Oct 29, 2008
I have a Sony DCR-TRV250 Digital Handycam Camcorder. Currently a tape is stuck in it and the camcorder won't eject it. The tape unit comes out but won't open.
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Nov 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Everytime i insert the tape i get this beeping sounds and flashing numbers on the screen.
Beeping and error code flashing shows that camcorder got some problem and usually its tape mechanism that needs qualified tech to check and fix.
Mostly its take-up reel section problems. Local camera tech will fix it.
Thanks.
Nov 12, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Everytime i insert the tape i have this beeping sound and flashing numbers on the screen
Sony camcorder has self diagnostic function inbuilt and if it detects any problem in listed sections it will start beeping, you can check error code that would be like C:31:10 or some thing on top right corner of LCD, let me know that error code to find out problem section in camcorder.
Thanks.
C:31:23
The camcorder has detected an issue that may require a power reset.
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
Aug 12, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
C 31
The camcorder has detected an issue that may require a power reset. To POWER reset the Camcorder,
Aug 06, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Feb 26, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Audio
DCR-TRV250 Sony camcorder needs Tape Path Adjustment to provide you correct sound because due to wrong alignment of tape drive on video-head, nosiy audio is being read and processed.
Nov 30, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
Sm. triangle flashes
I have found, that if you oilthe gears ( DO NOT OIL THE PLASTIC ROLLERS OR THE RECORDING HEAD, DO NOT USE WD40, USE AN ACTUAL OIL DRIPPER), and the hinge on the camera tape door, that it... So far has fixed my issue with the same problems and have been good for 6 months now. The camera would flach stuck tape, eject, and it would act as if it was stuck.
Aug 31, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
My camera function is not working
It could be that the tape heads are dirty. You should try cleaning them with a 8mm tape cleaner. Radio Shack carries them.
Feb 26, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony Handycam DCR-TRV250E Digital Camcorder Logo
162 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
