Question about Lite On LVW-5005 DVD Recorder
Why won't the disk tray open?
The tray would not open when I wanted to make a recording. There is a disk in the tray now, a recording I made previously. I played that disk back but, when I wanted to remove that disk, the tray would not open. What can I do?
Clean the belt and pullies that drive the tray with alcohol there is grease on the gears that spins up on the belt viola belt slips also, you can take an exacto knife to the inside of the pullies and scratch lines like tread for the belt to get grip. I even tried to change the belt with a smaller o ring, but could not find one exactly the right size. hope this helps Tim
Posted on Jan 03, 2009
  • 3,037 Answers
The motor has either burned out, or there is a misalignment of or a part that broke. You should unplug the device. Take off the outer cover and try to manually pull out the tray but first try to get the disk out. It will take mainly a #0 or a #1 phillips head screwdriver for the whole process. If you can open the tray and push it back in, then leave it out and plug it back in and see if the motor will bring it in. If it doesn't, then the motor is (most likely) bad or a wire has a loose connection (not very likely). Otherwise if, it does work, see if it continues to work, if not, see if anything is jamming, otherwise let me know and we will go from there
Posted on Oct 29, 2008
    President:
  • 2,712 Answers
Press the eject button and using two small screwdrivers on either side of the tray, try to manually coax the tray out GENTLY.
  • Swilin Sampson
    Swilin Sampson Oct 29, 2008
    Unplug the device from the power source for a minute or two and reconnect and see if this helps. If the issue still persists, it could indicate a failure within the gear mechanism that propels the tray, and would require servicing
The disk tray on the recording side of the recorder will not open.
use a paper clip to open. first strighten out the paper clip. make sure power is off to the unit. then with the paper clip insert into hole on the player. the tray will eject out. good luck.
Oct 24, 2014 | Audio Players & Recorders
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sep 19, 2012 | Panasonic DMR-EZ37VK DVD Recorder / VCR...
My 360 kinect won't read disks. It says open tray,
my x box 360 Kinect want work because when I put the game in it said open and close the tray
Apr 08, 2012 | Video Game Consoles & Games
Sony rdr-hx720 tray won't open and says traylocked?
The disc tray does not open and you cannot remove the disc after you press Z (open/close). ,Turn off the recorder. Once the clock appears in the front panel display, disconnect the mains lead. (If the recorder does not turn off or if the clock does not appear in the front panel display, disconnect the mains lead anyway.) Connect the mains lead again while pressing down A on the recorder, and release the button when the disc tray opens. Then, keep [/1 on the recorder pressed for about ten seconds until "WELCOME" appears in the front panel display
Oct 08, 2011 | Televison & Video
The tray will not open/eject on either deck; it tries to open but just says TOC no disk.
I have the same problem with both trays on a Sony RCD-W3 not ejecting. If you push the tray sometimes it opens, but takes a few attempts. the recording CD sometimes doesn't see the disk but ejecting and re-entering it normally gets around that. I have no permanent solution, I'm afraid. Probably needs to be opened up and rails greased/oiled or something like that.
Aug 31, 2010 | Sony RCD-W1 2-Disc CD Recorder
I put a blank CD into the tray to record. It
If there is a tiny hole somewhere near the tray you need to poke a needle or something like that in there to open the tray.
Dec 02, 2009 | Philips CDR785 3-Disc CD Recorder
Gateway DVD Recorder AR-230 Disk tray does not open.
Unplug for 2 hours. otherwise timing is off and timing needs to be adjusted or rubber replaced..usually Pro shop or open it up and look aroound , possibly a belt came off ??
Please rate!
rate please!
Mar 16, 2009 | Gateway AR-230 DVD Recorder
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Lite On LVW-5005 DVD Recorder Logo
302 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
