Question about Krups Orchestro 889 Espresso Machine
Krups orchestro 889/ power loss/spent coffee tray won't go back in/ did every thing in book/no help/makes noise and then all lights alternate off and on/tray will slide in w/o spent coffee holder/ is there a hard reset or a way to manually move the plastic that recognizes the spent coffee reservoir?
  • John Schedler
    John Schedler Oct 09, 2014
    Did you ever figure out or get a good answer on the fix for this?
  • John Schedler
    John Schedler Oct 10, 2014
    I have the same machine and the spent coffee tray wasn't going in and after cycling with pressing three times then clicking three times all the lights would cycle between red and green and the machine would do nothing. It turned out to be a jammed eject motion of spent coffee. the coffee was pressed in but wouldn't eject into the coffee tray so the flap wouldn't go all the way up making the tray not go in. I took the back of the machine off and used a screw driver to "help the unit up during the cycle". When the machine would screw down and PRESS I'd not do anything but as soon as it would screw up I would lever my screw driver and HELP it up....after two or three attempts it screwed all the way up and ejected the coffee and now it seems fine.
    New Friend:
Did you ever get a good solution or figure out the fix to this?
Posted on Oct 09, 2014
5 Suggested Answers
  • 2039 Answers
SOURCE: Cleaning and descaling Krups Orchestro 889
take a descaler solution never mind vinegar not strong enought 1part solution 1part water put that in our water container start the machine open valve let it drip for a few second untill you see the solution leave it like that for 10 minute after open the valve and do it again untill emty after you emty the solution clean water container very good fill it with water open the valve rinse very good because that solution is very corosif enjoy cheers
Posted on Jan 19, 2008
  • 5 Answers
SOURCE: krups orchestro 889 coffee maker,
Remove the the four screws at the rear of the machine you will need a pair of pliers to do this and remove the hinged lids on both sides.looking down from the top and to the front you will see a phillips screw on either side,remove these and the top will come off you will then see the channels that the coffee runs from the machine now just use a piece of suitable material to clean the pipe,easy!
Posted on Mar 17, 2009
  • 5 Answers
SOURCE: krups orchestro art889 water is coming down
Most likely the main O-rings have to be replaced. There is an excellent step-by-step instruction available on http://www.kaffeemaschinendoctor.de/Downloads:_:30.html under Jura, Aeg, Krups - It's in German, but Google can translate it. This repair is not for the faint at heart, but it can be done. The O-Rings can be found in any decent hardware store.
Posted on Oct 04, 2010
  • 5 Answers
SOURCE: krups Orchestro 889 , plastic piece broken
You can get a new float here:
http://www.smallappliance.com/product.asp?pid=12225&cur=USD&cam=GA_B_krups_parts&sid=18956&mid=15&gid=18960&prdCls=P&pfor=7105&shopBy=Brand
It's $11.99, which I find is a bit steep... For a piece of plastic... But then again...
Posted on Oct 05, 2010
I need a cleaner for the Krups Orchestro 889
Krups have their own cleaning tablets and descaling powder, your local Krups agent should be able to help you.
Nov 28, 2015 | Krups Coffee Makers & Espresso Machines
My orchestro 889 espresso machine light are flashing power cleaning
I have been through the book and it gives no information on flashing power and clean light together. Quite often a full dismantle, clean and lubrication of the brewing unit will make things better when they are acting incorrectly.
Oct 01, 2014 | Krups Orchestro 889 Espresso Machine
Krups 889 red & green lights alternate flashing and machine will not do anything else. how can I get it out of this mode?
Jan 09, 2013 | Krups Orchestro 889 Espresso Machine
Krups orchestro art889 water is coming down into drip tray and coffee grout holder instead of the coffee dispenser
Mar 26, 2010 | Krups Orchestro 889 Espresso Machine
No coffee coming out of front taps
The brewhead is blocked the machine will have to be stripped and cleaned and the o rings replaced.
Mar 13, 2009 | Krups Orchestro 889 Espresso Machine
Coffie in the restcontainer
I took out the the spent coffee holder and inside the coffee machine I had to push back a rubber ring in it's place. Now it works fine.
Sep 06, 2008 | Krups Orchestro 889 Espresso Machine
Jan 19, 2008 | Krups Orchestro 889 Espresso Machine
Krups Orchestro 889 Espresso Machine Logo
191 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
