Goodman furnace Furnace kicks in for about 30secs and then shuts off. Have reset switch, trippied circuit breaker. Tried to reset thermostat.; This furnace is only 1 year old and was working well until 2 days ago
  • Anonymous Mar 25, 2014
    goodman furnace shout off when I turned it back on the thermostat reads in recovery mode
Sounds like the fan switch in the furnace is coming on and off. This is common for Goodman. or could be the heat anticipator on the t-stat. While there are several reasons this happens these are the most common.
Guy
Posted on Oct 30, 2008
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
Code 1 on a goodman furnace. Changed filter, reset thermostat, hit the breaker for reset and still the temp is dropping and the unit is not kicking from the thermostat. Thermostat is only a year old.
You unit is under locked out mode due fail on start up. Get sand paper clean out the flame sensor, and jump the 2 wires that go to the pressure switch as soon as the inducer came on. Doing this the flame should stay on until it meet set temp at thermostat . If it does what said your pressure switch need replacement . Good luck and keep me up to date .
Feb 02, 2014 | Goodman Heating & Cooling
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
Jan 07, 2013 | Goodman Manufacturing Goodman HKR-10C 10kW...
I have a Goodman GMP 125-5 furnace. It had a 3 light code i replaced the presure switch now it is giving me a 1 light code please help
A sampling of various failure codes on a furnace:
Read one LED flash that stays on continuously to mean your furnace has no signal coming from the thermostat and will not operate. Turn the power off and check the thermostat for improper settings or connections.
Interpret one LED flash that blinks on and off to mean your furnace has locked out because it could not ignite after three tries, and must be reset. Interrupt power to your furnace for 20 seconds or lower the thermostat so your furnace does not try to heat, then reset the thermostat to the previous setting. After one hour of lockout, your furnace will automatically reset itself and try to operate as usual.
Decipher two LED flashes to mean the draft blower is not working, or your furnace has a short in the pressure switch circuit. Turn off the furnace power and repair a short or replace the pressure switch.
Read three LED flashes to mean your furnace has an open pressure switch circuit or it has an induced draft blower operating. Check the pressure switch hose of your furnace for blocks or an improper connection. Also, look for blockages in the flue, and tighten any loose wiring.
Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Read seven LED flashes as a warning of a low flame sense microamp signal. This could happen with a coated flame sensor or a lazy flame from poor gas pressure. Turn off the power and adjust the gas pressure according to the information on the rating plate.
See eight LED flashes as meaning an igniter circuit problem due to a bad igniter or an igniter connected improperly. Replace the bad igniter or check the ground wiring, making necessary corrections.
Decipher nine LED flashes to mean the high-stage pressure switch circuit will not close during a high-stage-induced draft blower operation. Your furnace may have a pinched or blocked pressure switch hose, a blocked flue or loose wiring.
Read continuous flashing on the LED to mean your furnace has a reversed polarity of 115 volts. Turn off the power and correct the wiring polarity after reviewing the wiring diagram.
Oct 28, 2011 | Goodman Heating & Cooling
Furnace runs but once it gets to teamature it does not shut off but goes in and out of stages
Disconnect the thermostat wires from the circuit board. Tape door switch closed. Put a jumper on R and W on the circuit board. Let the heater run for about 5 min. Disconnect the jumper, furnace should shut down. If it continues to run you have a bad board. When you reconnect the thermostat, look for a shorted wire or a bad thermostat. I suspect a bad board if the furnace is hunting thru the stages.
Nov 03, 2009 | Goodman GMS90703BXA Heater
I have outside Goodman-Janitrol furnace and air unit and
two things to try first to get you pointed in the right direction. First disconnect the R or RH wire from the T-Stat. If the furnace turns off (Stops firing w/ fan to turn offabout 90 sec. later) then you more than likely have a bad Thermistat. If it continues to run Pull the R wire from the Furnace circuit board. put door back on furnace if it stops you have a short in the wire. Still Running? Most likely a bad curcuit board. Hope this helps.
Oct 12, 2009 | Goodman GMS90703BXA Heater
Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Jan 15, 2009 | Honeywell Electronic Programmable...
My gas forced air furnace is shutting itself off after 2-3 cycles
there is a thermo-sensor switch next to the circuit board that tells the fan switch to turn on when the plenum is hot enough. this needs to be replaced.
Dec 01, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
348 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
