Question about KitchenAid RRK150 Stand Mixer
How do I Open Up a KitchenAid RRK150 Mixer?
I can't seem to figure out how to get the top cover off of the KitchenAid RRD150 mixer. Can anyone give me a hint as to what the secret is to get inside to look at the motor?
When the motor on my unit runs, the beater only agitates intermittently. I'd like to get the cover off to see exactly what's going on.
Thanks!
  • Anonymous Dec 15, 2008
    SO HOW CAN U TAKE OFF THE COVER OUT
    IT SEEMS AS ITS ONE WHOLE BLOCK
    THANKS
You have to take the pin out from right above where you put the beaters on, and then you can tap the circle part off, and get into the inside...
Posted on Aug 10, 2009
  • 118 Answers
You probably have a stripped gear. You can find the parts lists HERE.
Posted on Nov 30, 2008
Tripped circuit & heard pop on KA Artisan Mixer #RRK150 while using pasta press attachment. Now doesn't run. Fixable OR replace?
probably fixable. The load of the pasta press may have blown an internal fuse or overheat thermostat, taking the breaker with it. Open it up and take a look.
Kitchen Aid Artisan Mixer RRK150 spares Google Search
Apr 23, 2017 | Food Mixers
Kp26m1xwh Kitchenaid mixer 575 watt stopped working.
On the back of the mixer is a screw holding on the Kitchenaid name plate band that wraps around the mixer. Remove this screw and the name plate and then you'll see four screws (two on each side) holding on the top cover for the mixer. Remove the four screws and then lift off the top cover and you'll see the motor, circuit board and gear box that operate the mixer.
May 29, 2010 | KitchenAid KP26M1X Stand Mixer
Rrk150OB is drooping an dthe pin keeps falling out
I assume you mean the pivot pin on which the top half of the mixer pivots to remove the bowl is sticking out of the side of the stand. Turn the mixer upside down and look up inside the stand which is hollow. You will see a screw. Tap the pin back into position and then tighten the screw.
Now to fix the drooping, and I assume you mean the beaters are hitting the bottom of the bowl, tip the mixer back and look into the hinge area. You will see a rather large screw. Turn it ccw a turn and check the beater to see if it is still hitting the bottom of the bowl. Repeat the procedure until you have 1/4 inch clearance or so from the bottom of the beater to the bowl.
Mar 28, 2010 | KitchenAid RRK150 Stand Mixer
My wife droped her kitchen aid mixer RRD150 now it wont come on. I dont see any thing broke in side.
could be motor displacement from brushes to armature
estimate cost $39.-$59.00
4-5day repair time
ship USPS it's very inexpensive
Nov 20, 2009 | KitchenAid RRK150 Stand Mixer
My KitchenAid RRK150 325 Watts Stand Mixer started to smell more and more when used for more than 5 minutes. Now it doesn't work anymore, nothing happens when power is on. I'm not sure whether it's the...
It sounds like your problem will be in the back of the mixer then. Take the back cover off and have a look inside. Usually an electrical smell is also accompanied by sparks when the mixer is turning and often blackening of the area where the sparks are occurring. As the turning motor makes physical contact with the control plate I would investigate the area at the back of the motor. It may be that a new control plate is required.
Oct 20, 2009 | KitchenAid RRK150 Stand Mixer
Bolt holding the top that has the mixer on is out to far
Hi. Go to mendingshed.com click on kitchenaid, then kitchenaid mixer parts. Near the top of the page, locate and download the FREE Kitchenaid Service Manual. This valuable document covers all aspects of your K45SS mixer. If you determine that you need KA parts, have Mending Shed give you a quote. Go to kitchenaid.com select Customer Care then select Locate Manuals. Once you're at the search window, enter your model# this way: K45SSwh, toward the bottom of the page locate and download the parts list. With the parts list and the service manual in hand, you are now ready to tackle your mixer project.
You can also order parts from kitchenaid...Just be prepared to wait at least a month for your parts to arrive. Good luck! ricardok45
Apr 28, 2009 | KitchenAid K45SS Classic Stand Mixer
Motor is running, but mixer not turning
hi mary. there is a phillips head screw in the rear of the mixer head. if you turn the mixer around you will see it in the band. remove that screw then remove the other four screws that hold the top on the motor cover. good luck with it.
Jan 20, 2009 | KitchenAid K45SS Classic Stand Mixer
My kitchenaid standmixer started to smoke, need to open
See my posts on removing the motor cover. DO NOT USE this mixer if it smoked. Something needs to burn to cause smoke. I doubt you can fix this without new parts.
Jan 02, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Need user manual for Kitchenaid Artisan Series Mixer Model RRK150 OB serial no. WS 1208816
Looking on the KitchenAid site, your model did not look up, buyt I put miune in and this is the link to download the manuals.
Nov 25, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
Kitchenaid mixer makes a clanging noise
Hi. If your mixer is under warranty, call Kitchenaid. They are very good at replacing mixers under warranty.
If you are out of warranty, this is where the fun begins, NOT!
Remove the silver band from around the top of mixer. Remove 4 screws that secure the top cover, remove cover and at the front top of the machine locate the transmission cover. Inspect this cover carefully for cracks. If you find cracks in it...You have just discovered Kitchenaid's dirty little secret. A cheap plastic transmission housing! The failure of this cheap part is the cause of all of the rest of the damage inside the mixer, which may include a destroyed worm gear and shaft, destroyed bearings and their seats. You're not alone. I estimate that thousands of these plastic parts have failed causing great damage to the rest of the mixer
Kitchenaid's replacement housing is made out of metal. If you feel up to the task of repairing the mixer yourself goto the Kitchenaid website and do a search for the parts catalog for your mixer model, these will assist you with disassembly, reassembly and parts ordering.
If you're not up to the task, take it to an authorized repair place once you have put the cover back on.
Even if you're out of warranty, you may be able to have Kitchenaid pay for the replacement parts, they did for my mixer. Be persistent with them and try to get to a manager with your complaint. This cheap piece of plastic has no business being installed on a high-priced machine.
If this solution has assisted you, please rate it. ricardok45
Nov 10, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid RRK150 Stand Mixer Logo
341 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
