Question about Vulcan 36L Gas Kitchen Range
Vulcan range that won't heat.
Hi, Thanks very much for your opinion on the range - that's it probably a pressure or regulator problem. My problem now is that I can't find anyone to work on it since it's a commercial range in a residence. Does "Hobarttech" indicate you work for Hobart (in Minneapolis, by any chance)? I had a person from Hobart out a few years ago and he calibrated it and declared it "fine," which it wasn't. So how do I find someone, maybe a technician who is willing to moonlight on a job like this, so I can get it fixed.  I am happy to sign a waiver, ignore code, or whatever it take to get this stove working properly.  My wife says to fix it or we need to get a new stove - and I can't disagree as I wait 10-15 minutes for a small pan of water to boil. Thanks for any help you can give. Mike Miller
  • Mayk Oct 29, 2008
    Someone told me it would be hazardous for me to replace the unit but I'm very handy and, as long as it's a preset unit, I don't know why I shouldn't do it.
    Thanks again.
    Mike
    Scholar:
  • 112 Answers
Yes, I am a technician for Hobart, in Michigan. If your burners are uniformly low, and you know it is set up for the fuel you are using, swap out the regulator. You should be able to buy a pre-set regulator, just make sure it is for the correct gas. If you don't feel comfortable, call around. I'm sure someone needs the business.
Posted on Oct 29, 2008
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
My weber grill won't heat up beyond 200 degrees - why>
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101 ,,./,./
May 28, 2011 | Weber Genesis Silver B Grill
Our maytag gas range won't come up to heat
Your problem could be or probably is with the regulator...not enough gas pressure...
heatman101
Feb 02, 2011 | Maytag Kitchen Ranges
Having just converted my Vulcan Endurance G36L Range from Nat. Gas to LPG Using the following parts recommended by Vulcan : New 1/2 psi pressure regulator, 6 size 51 hood type top burner orifices,1 size...
The oven safety valve has to be cranked down for propane.themobilian_815.jpg
Get a good fitting wrench and tighten this spud down and open the air shutter on the burner.
This video shows how to tackle a crank down and flip type LP conversion whilst yours might be a bit more fancy it still must be adjusted like any other stove:
Jan 10, 2011 | Vulcan G36L Gas Range
What can cause the oven to heat real slow
You problem could be or probably is with the regulator...not enough gas pressure...
heatman101
Sep 21, 2010 | Maytag MGR5751AD Gas Kitchen Range
Vulcan Range that wasn't heating.
The half inch tubing should be adequate under most circumstances. However, you may run into volume issues while using the oven and a few burners at the same time. If it bothers you, replace it. The door should be flush (or close to it) on the sides and the top. If you have an air gap, check the hinges.
Nov 10, 2008 | Vulcan 36L Gas Kitchen Range
Burners heat very slowly, oven has to be set 50 degrees higher than desired temp. to get the right heat.
First, you should make sure the unit is set up to run the type of gas you use. If you have natural gas and it is set up for lpg, or vice versa. If it is wrong, you can retrofit it by changing out the orifices. Other than that, check your pressure at the manifold that feeds the burners to see if it is adequate. A bad regulator could very easily cause this problem as well.
Oct 28, 2008 | Vulcan 36L Gas Kitchen Range
Vulcan 36L Gas Kitchen Range Logo
190 people viewed this question
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
starztruck4u
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
