Question about Wintergreen CMV CT-723A 17" LCD Monitor
Ct-723A monitor I was moving my monitor and the screen flipped upside down maybe for another mounting position do you know how to return the screen to normal
0 characters
1 Points
What power adapter, what power supply should I buy as I lost the last one
see its model number and buy another with this model number.
these numbers must be same completely
Apr 08, 2016 | Wintergreen CMV CT-723A 17" LCD Monitor
What size power supply is used
it uses 19V AC power supply adapter.
Dec 31, 2010 | Wintergreen CMV CT-723A 17" LCD Monitor
Upside down screen on monitor
turn your monitor upside down on your desk and look near the clock at the bottom in the system tray. you may have a shortcut there to that video setting, hover above the icons next to your clock, hopefully one of them is your video settings and study in there to change the setting back to the way it was. if not then right click the destop, go to properties, then go to settings in your display properties, then click advanced, and right in there should be a setting to flip the screen 180 degrees back to the way it was..
Dec 15, 2009 | ViewSonic VX2235WM Monitor
Image on monitor is upside down!
most the time pressing CTRL ALT UP ARROW together will flip the monitor back right side up
CTRL ALT DOWN ARROW will flip the screen upside down
Dec 05, 2009 | Acer Computer Monitors
Monitor clip
the solution for you is to take your monitor and flip it upside down and re-align the slot on the monitor clip /stand so that it lines up with the front of the monitor. Return the monitor back to its normal position on the desk and it should now behave properly.
Good Luck!
Rich Lilja
Nov 25, 2008 | Computer Monitors
Everything is flipped
in the video settings you will see an option that will flip it back to normal
good luck
Apr 01, 2008 | Dell E176FP 17" LCD Monitor
First post is misleading...sorry..not one pin bent bb.but none were bent (typo) sorry
It could be the monitors invertor board has gone bad. Call a local computer shop and tell them you need a new invertor board for your monitor and see what they say. Write me back and let me know.
Jun 25, 2007 | Wintergreen CMV CT-723A 17" LCD Monitor
No Video
Did you take the monitor out and put it back in before the pin was bent? Or did it just all of a sudden blank out.
Jun 24, 2007 | Wintergreen CMV CT-723A 17" LCD Monitor
Screen has rotated 180 degrees
I have lots of Dell monitors and none of them has the ability to flip the screen orientation built into them. What I suspect has happened is he accidentally hit a keystroke combination that activated a feature in your video card driver. If you have the built-in Intel Extreme Graphics read this link and let us know if it helps.
Dec 30, 2006 | Dell E173FPc 17" TFT LCD Flat Panel...
Wintergreen CMV CT-723A 17" LCD Monitor Logo
59 people viewed this question
Top Wintergreen Computer Monitors Experts
Electro Med Services...
Level 1 Expert
Are you a Wintergreen Computer Monitor Expert? Answer questions, earn points and help others
