Question about Lite On Televison & Video
The disk tray won't open. There is a dvd in the tray and I played it back but, when I tried to eject it, the tray door would not open.
    Genius:
  • 1,550 Answers
The sensor is stuck . Motor is not working properly. To remove dvd try hard reset .
Else you need to unscrew to get the dvd out of the player .
Posted on Oct 29, 2008
    Scholar:
  • 155 Answers
Check if something is blocking the door to open.if no then the gears in the internal area are either worn out.apply the oily substance in the sides of the dvd gears to make it move frequently.
thanks.
  • fixexpert Oct 29, 2008
    to remove the disk manually for now.just OFF the pc and take a thin metallic material like needle .in the front area of the dvd area you will see a very small hole just slowly insert the needle in it and press slowly.the cover of the dvd player will slightly come out just pull the door slowly with your hand.and remove the dvd disk from the player.then you can check the side gears of the door which came out.apply oily material to that gears.and push the door IN/OUT 3-4 times with your hands and then ON the pc and check it should work..
    and the other reason that the dvd door is not ejecting is that the dvd which you inserted in the player is broken inside and that is blocking the door to come out.if that is the case then you have to remove the dvd player from the pc.then on the back of the player there r four screws just remove that screws and the top area will be removed and now you can see the dvd disk in that player,remove all the broken dvd disk parts.
    rate the solution if helped.
    feel free for further assistance.
    thanks.
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
My CD & DVD ROM drives will not open the door so I can insert a disk. The disk that is in the CD ROM that I can't get back out will play but the DVD ROM will not play anything at all.
Hello and Welcome to FixYa!
Your DVD rom tray may be stuck inside. Try the emergency eject by inserting a paper clip in the small hole at the front.
Regards,
Waqar
Dec 24, 2009 | Dell XPS 400 PC Desktop
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
Dvd burner won' eject dvd
On the front of the burner there is a pin hole. Take a paperclip and unfold it so it's a point. Stick it in the hole and it should open the tray. This should FixYa!
Jan 27, 2009 | Lite On LDW-401S DVD+RW Burner
The tray won't open. There is a disk in the tray and I was able to play it back. But, when I tried to eject the disk, the tray woudn't open.
something like this is a physical problem. you should contact the manufacturer to see if there is a manual eject button and if not you will have to take it apart to get the disk.
Oct 29, 2008 | Lite On LVW-5005 DVD Recorder
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Disc Error, and DVD tray ejecting on it's own....
If it is new, best advice is to take it the Comapny Service Centre, as you are having Warranty.
Apr 04, 2007 | Sanyo DVW-5000 DVD Player/VCR
Televison & Video Logo
167 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
