Question about Sewing Machines
Pfaff Hobbylock 784 parts
Please, Help me find the two screws that hold the needels in place.
4 Suggested Answers
SOURCE: pfaff hobbylock serger 784 786
I cannot make a roll hem on my Pfaff 784
Posted on Sep 26, 2008
  • 3 Answers
SOURCE: Pfaff hobbylock 794
The needles are changed by inserted the hex wrench into what looks to be holes on the front and left side where the needles go into the machine.I'm not sure what size the hex wrench is but it's pretty small. From the manual,
"Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out." and
"Inserting needle: When the neddle bar is at the highest position, insert a new needle in the needle holder, making sure that the groove of the needle faces you. Push the needle as far up as it will go and tighten the needle clamp screw." "Removing Needle: Unplug the machine. Turn the handwheel counterclockwise to raise the needle bar to its highest position. Loosen the needle clamp with the allen wrench and pull the needle out."
The machine takes DB x 1, or 1738 needles, and a size 14 needle is recommended.
Hope this helps!
Posted on Jan 13, 2009
  • 35 Answers
SOURCE: Pfaff hobbylock 4860 needle bar. the needle binds
Many users also reported the same locking problem on their sewing machine. Do you want to try fix it by yourself? I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Posted on Sep 08, 2010
Where to find a Replacement Spool Holder for Pfaff Hobbylock 794
Pfaff Hobbylock 794 Parts
You can also try eBay. If not lucky there, try finagling one using a nail with a drinking straw over the nail to hold the spool.
Jul 17, 2015 | PfaFF Sewing Machines
Where can i bye replacement motor for PFaff hobbylock 784
Hi Dennis, you could try "Sewing Parts Online" (link follows) I don't see you motor listed but if you contact them I'm sure they would be able to find one for you.
Trust this helps, regards Alan
Link --> Pfaff Parts by Model
Mar 03, 2015 | PfaFF Sewing Machines
I want to bye a new motor for Pfaff HOBBYLOCK ELECTRONIC 784 MACINE.
e-bay has a selection of new motors available for sale
contact a pfaff service agent and see if they are still available. unless the motor smells or smokes I would have the machine serviced as it may be cotton waste wrapped around moving parts that is jamming the machine indicating a failing motor.
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
http://www.pfaffmachines.co.uk/overlock/pfaff-hobbylock-2-overlocker.htm
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
I have a hobbylock 776. The square box on the shaft that holds the needles is broken. I think the holes for the screws are stripped. I believe it is the needle bar. Can not find a part.
You will need a new needle bar. Call your local Pfaff Dealer, as this part is only available from them (if at all). The needle set screw holes could possibly be tapped and fitted with different screws as a last resort, but I wouldn't count on it.
Jan 02, 2010 | Sewing Machines
I am looking for pfaff hobbylock 786 serger manual do you know where I can get one?
ISBN 0-8019-8192-1(hc)? or ISBN 0-8019-8191-3(pb) by Naomi Baker & Tammy Young - "Know Your Pfaff Hobbylock" covers Pfaff Hobbylock: 797, 786, 784, 783 - Great book. This book is more helpful since it has detailed info pics in color- 182 pgs, @$3.00. Lists parts, projects, etc. The 786 manual has errors, 35 pgs. not detailed as the book above. Good luck! Fairlyart
Mar 12, 2009 | PfaFF Sewing Machines
Pfaff hobbylock serger 784 786
Sep 06, 2008 | PfaFF Quilt & Craft Pro 7530
Hobbylock 774
If the needle bar is no longer available, the current needle bar can be repaired by cutting new threads in it and changing the screw. Not simple but not rocket science either.Most mechanics can do this.
sewman7
Aug 08, 2008 | PfaFF Creative 7570
Sewing Machines Logo
265 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
