Question about Brother MFC 1950MC Printer
"Machine Error 81" message when I tried to set up my 1950 MC
My Brother MFC 1950MC has been inactive for a few years. I tried to set it up today and begin using it again. I got the "Machine Error 81" message. I sure hope it's resolvable.
Thank you,
Jay Squires
  • 2 more comments
  • jayboid Oct 29, 2008
    This may cost me another ten-spot, because that problem is corrected and a new one arisen. When I use the copy function only the left side of the page prints. When someone faxed something to me only the right side printed. Let me know if I need to pay another $10 for your answer. thanks.
    I might understand getting a new printer when only the right half prints when using the copy function and the left half when receiving a fax, but -- and this is going to sound stupid -- are you assuming the printer is separate from the fax? If it is part of the fax machine, as mine is, wouldn't I have to get a whole new fax machine???? Thanks again, Guru.
    I didn't get my last question answered (which I put under comments instead of a new post, the latter of which implied that I wanted a different expert). Anyway the answer I got was a repeat of the previous one. Here is my unanswered question which I'm pasting here:
    Helpful -- disappointing, but helpful! I know I need to get a new fax machine, since parts would cost more than a new printer. What was not adequately explained to me is "What is the difference between the printer and the fax machine itself?" You told me an HP printer was good. So... how do I get a fax that is sent to a "Brother" print on an HP? Am I the only one having trouble visualizing this?
    President:
  • 2,712 Answers
Try reinstalling the driver. That usually resolves these kind of errors, where only a part of the page gets printed.
Posted on Oct 29, 2008
  • 728 Answers
Well if the printer and the fax machine are connected, it woulb be hard to replace the fax machine without replacing the printing part. And that will not solve the problem. It seems as though your internal memory only remembers half of what is supposed to be printed. The internal memory may have gotten cluttered after the few years it had been sitting. If possible, try resseting it if there is a button for it and if not or it doesn't work, try restoring the factory settings using the menu button. That should work.
  • Brother Master
  • 19,396 Answers
"When I use the copy function only the left side of the page prints"
That is because toner is not melting properly.
Remove toner cartridge, put it back in place and print like ten pages or so, if this cannot fix the problem, then there is a problem with the drum or with the fuser unit.
  • Ginko
    Ginko Oct 29, 2008
    I apologise for the confusion, but the system is temporarily malfunctioning, and presenting you the solutions one by one.
    Each expert works on his own, check here the whole thread:
    http://www.fixya.com/support/t1185383-ma...
  • Ginko
    Ginko Oct 29, 2008
    Genius:
  • 1,550 Answers
The manual says "Machine Error xx - contact your Brother dealer for service".
You cannot repair at any cost sorry to say this .
  • 6,487 Answers
This error message is telling us that there's a some hardware error/failure already on your printer and it will need some part replacement , but the price of the repair plus part replacement is equal as getteing a unit , so I suggest you just go ahead and get a new unit ....
  • Mark Gil
    Mark Gil Oct 29, 2008
    No need to pay another 10 bucks , you will only be charge one until you accepeted a solution and rated it FIXYA, with the problem of yours you can fix it but after that there's always another problem to arise...
  • 3,037 Answers
Basically this error is one that will cost more to fix than to get a new printer. As you would need to replace parts that aren't sold separately, the only thing you can do to try to fix it is unplug it and replug it in and hope that it goes away. If it is still under warranty, then get it fixed, otherwise look for a new printer. HP printers are very reliable
email brother and they will tell you the same thing
good luck and let me know if you have any further questions regarding this
  • Benjamin Patri
    Benjamin Patri Oct 30, 2008
    I'm sorry if I didn't respond sooner, I am very busy, as I believe you are and had other items to attend to, but with the new info, it is definitely in your interest to get a new printer if the fax is failing. Sounds like the computer on this is bad and so everything is going bad.
    I'm sorry if I didn't spell out the exact wording of th manual saying that any error that doesn't reset when unplugged and replugged requires service like findmeifyoucan but The reason I said you are better off with a new printer is basically because this one is done, and I recommend an hp printer because you can buy one (an all-in-one) with a fax, copy, print, and scan (black and/or color) and they generally outlast other brands I believe from what I have seen. The expensive part of all printers is the ink and so unless it is a simple and quick fix, look for a new printer. Please don't feel the need to fork out another $10 but Please let me know if you need anything else and I would appreciate it if you took the time to re-rate my solution as a solution rated as "Fixya" is well worth the time I put in.
  • Brother Master
  • 13,433 Answers
Machine Error XX indicates a mechanical malfunction of the FAX/DCP/MFC. "XX" represents the error number. Unplug the unit from the power source and then plug it back in.
Its a internal problem, have you already contacted Brother about the issue?
    Scholar:
  • 155 Answers
Check for any papaer jam or any dust material blocking the rollers of the printer to move.OFF the printer.and blow air through the blower in whole internal area off the printer.then ON and check.
thanks.
  • fixexpert Oct 29, 2008
    no not another $10 for the answer.
    its simple the problem is that your cartridge is near to end.so it should be refilled or replaced with new.as u said you started using out you printer after few years.may be your cartridge must be full but the powder inside your cartridge has gone moist and needs to be replaced.
    now your printer is having no problem.only the cartridge is empty or gone moist.get your cartridge refilled or replace it with new.
    rate the solution if helped by it.
    feel free for further assistance.
    thanks.
Brother MFC 8500 Fax machine error "offline"
is your fax machine connected to the phone line? this usually indicates the connection status, thus, if your phone line is in...you wont have the "offline message".
hope this helps.
Jan 23, 2008 | Brother MFC 8500 All-In-One Laser Printer
How do i turn the unit on?
Simply plugging it the cord into an active electrical outlet will do the trick. There's no rocker switch on the back.
The MFCs tend to go into a power-saving mode where they are silent.
Look for signs of life on the tiny LCD screen.
If this doesn't answer your question, then follow this link to the Brother MFC 1850/ 1950 MC/ 1950 MC PLUS printer manual.
Oct 30, 2010 | Brother MFC 1950MC Printer
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Confirmation on fax
You can set the machine to print out a confirmation that the fax went through successfully. Check the fax settings in your manual.
Nov 29, 2008 | Brother MFC 1950MC Printer
Cannot get dial tone on phone
I would suggest unplugging the unit and let it sit for about 15 minutes. Make sure there are no paper jams, and then plug it back in and turn it on. Also, check the phone line with another phone instrument.
Make sure to put the phone wire back in the right port.
Plug in and power the unit back on and test it.
If it is still failing, then I am sorry to say that it might be time to get a new unit.
Nov 22, 2008 | Brother MFC 1950MC Printer
Error message on my mfc 420 mc
this has been written many times here in the forum.
plz search forum "unable to print"
Jun 22, 2008 | Brother MFC 420CN All-In-One InkJet...
Error Message "Unable to init 46"
error 46: waistink absorber needs replacing. you must have run quite a lot of manual cleaning cycles in case your mfc is about 1 year old....
Feb 26, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC 1950MC thermal ribbon fax machine
Sounds like print heads are fried. I found this guys website ebay@laseractionplus.com he says he has lots of brother parts and his rating is good. Otherwise you might have an auction of your own to sell your PC101 carts. As far as your Ebay problem, that's why they have a dispute department and feedback. Good luck
Aug 30, 2007 | Brother MFC 1950MC Printer
Brother MFC 1950MC Printer Logo
156 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
