Question about Toshiba 32AF41 32" TV
Green is not being displayed on my TV
I bought my TV used about a month ago and up until now there have been no problems. I turned the TV off last night and when I turned it back on this morning it looked weird. After a quick investigation I found that the color green was not being displayed. The OSD that use to be green is now black. Tried several different inputs including the colorstream, and nothing will display green. I took a picture of the TV to show the problem (http://img.photobucket.com/albums/v666/Stirlin_05/TV.jpg) The LED in the back should be green as well as the black circle next to the red circle on the blue background (right side of screen). Any ideas?
    New Friend:
You chk with RGB drive voltage and re solder the nick board.
Posted on Dec 29, 2012
    President:
  • 3,130 Answers
If you have experience troubleshooting solid state TV sets, you should be able to tell by a couple of voltage measurements if its a problem with the picture tube or the drive circuit. Simply take the multimeter and compare the base voltage of the green drive to the red or blue drive transistor. If the voltage is about the same, measure the collector of all three. if the green voltage on the collector is higher then the others, then theres an open between the drive transistor and the crt element. this could be an open resistor, a bad solder connection on the crt socket, or an open picture tube element. If theres no voltage there then your going to have to trouble shoot the drive circuit.
Posted on Sep 08, 2006
SOURCE:
My t.v display and sound will not turn on after the t.v has been turned on.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 21, 2012 | Vizio 32" E321mv 1080p 60 Hz Lcd Led Razor...
My sceptre lcd tv is displaying really bright pink and green colors
I had a similar problem with blacks showing up as green. Turning up the brightness a bit fixed it for me. Not a permanent fix, but something to try if you want to make it last a bit longer until you can get a new one or fix it.
Mar 24, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
I bought my plasma tv over 1 year ago but only set
it's a defect. we call it red blinking death. the boards inside the tv has gone bad.
Oct 17, 2009 | Panasonic TH-50PX75U Plasma HDTV
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
OSD not working (black screen)
Your 635 will not display the OSD screen through component. You must use either s-video or rca. It won't upconvert the screen menu this route.
I had one up until a week ago. There are two outputs on the back specifically for the OSD screen. I used a separate old 13" TV with s-video to do my setups. Hope this helps.
Sep 04, 2008 | Harman Kardon AVR 635 Receiver
Sansui Plasma, Green and Red Snow
I have the same tv - change the power supply. Corne Bronkhorst
Mar 14, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Z50px2d
Technician just replaced the upper right (from the back) circuit board that conects to the panel. TV now works fine. I bought the display model 8 months ago with extended Circuit City Warranty for $1000 so I can't complain. This was covered entirly by LG/Zenith (nicest Cust. Svc. ever) so we'll wait and see what happens.
Dec 10, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Television turning off whilst being viewed
This might sound weird but can you locate the infra-red sensor and glue something on it so it doesn't respond to your remote control? A different device in the neighbroud might turn it off.
Oct 23, 2007 | Televison & Video
Toshiba 32AF41 32" TV Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
