Question about Lexmark X7170 All-In-One InkJet Printer
Fax setup Our home phone and fax are on the same line. Is there a way to set up the fax so that it will recognize the differance between a phone message and a fax and be able to print the fax?
I set my fax on auto answer with a short number of rings. My answering machine is set up to ring more. If I am receiving a fax it picks it up; if not, the answering machine comes on after the designated number of rings. Thus far this has worked for me. Good luck.
Posted on Dec 28, 2008
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
I have Epson SX600FW and am trying to set up the Fax capabilities plus have a phone attached to the printer. I connected the printer\fax Line to the BT socket and the phone to the EXT socket but got no...
https://www.epson.co.uk/support?productID=2933#manuals
Download Fax Guide.
Note instructions for DSL phone line is different than regular phone line. The fax manual there has pictures of how that is done.
If BT is faulty, they offer support:
From the UK: 0800 800 150*From outside the UK: +44 179 359 6931*
Our repair teams are open:
7 days a week, 24 hours a day
* The cost of the call depends on the country and network you're calling from.
http://www.bt.com/help/home/contactus/#/landline/fix-landline-problems
Feb 06, 2018 | Epson Stylus Multifunction Printer/...
Need to set up machine was given as gift
There are two ways to use a fax machine in your home or office. You can either have a standalone fax machine, or you can use your computer for this purpose. Either way, setup is very simple. You don't even have to be a tech guru to do it. First, decide if you'd like to have a separate phone line for your faxes so they don't interrupt communications at the office. If so, have the phone company install the line before you get started with fax setup.
Setting Up a Traditional Machine
  • Step 1.Set your fax machine on a flat and even surface. Plug the power cord into the wall. Fill the paper tray and slide it into the front of the machine.
  • Step 2.Plug one end of a standard phone cable into the phone jack and the opposite end into the port on the fax machine. It's usually on the back or the side.
  • Step 3.Turn on the machine and pick up its telephonemag-glass_10x10.gif. If you don't hear a dial tone, check your phone cable to make sure it's secure. Then turn to the LCD screen and start programming your options. Since all machines are different, see the instructions in the owner's manual.
  • Aug 03, 2010 | Office Equipment & Supplies
    Need to set up phone/fax instead of just fax
    I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
    First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
    Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
    How to set up fax number on my 7310 all-in-one.
    According to the HP manual for this unit:
    1. Verify that your HP all-in-one is set to answer fax calls automatically. (Press the Auto Answer button so the light is on.)
    2. Press Setup.
    3. Press 5, and then press 1.This displays the Advanced Fax Setup menu and then selects Answer Ring Pattern.
    4. Press the down arrow key to highlight an option, and then press OK. When the phone rings with the ring pattern assigned to your fax phone line, the HP all-in-one answers the call and receives the fax.
    You can download the manual from HP here if you've misplaced yours and need more setup information.
    Apr 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
    Fax doesn't recognize incoming phone call
    Try this: using a cell phone, call your fax. Listen on the cell for a busy signal, fax tones, dial tone, etc. If the fax does not answer the cell, check the following: make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to connect a TELEPHONE to the fax. If problem still exists, press MENU on your MFC, and scroll to GENERAL SETUP, FAX. Scroll to SETUP RECEIVE, and, after writing down the settings, try changing the RING DELAY or RING TIME settings. If problem is still there, press CLEAR/BACK button until GENERAL SETUP appears on screen. Scroll down to INITIAL SETUP, and select RECEIVE MODE. Try changing RECEIVE MODE settings. Write them down before you change anything.
    Sep 01, 2008 | Brother MFC-5840CN All-In-One InkJet...
    Fax network not working
    Is your phone line plugged into the proper receptical on the fax? It should be plugged into the LINE slot, not the PHONE slot. The PHONE SLOT IS TO CONNECT A TELEPHONE TO THE FAX. IT IS NOT FOR THE INCOMING PHONE LINE. If your phone connection is correct, try calling your fax machine from a cell phone while you are at the fax machine. Listen on the cell to see if the fax machine picks up the line. If it does not, go into your fax machine's settings, either INITIAL SETUP FAX SETUP, or PHONE SETTINGS. You may have to try several settings to find one that works, depending on your fax machine. Try going to RECEIVE SETUP on your fax machines setup menu. Scroll through the settings, writing each down on paper. Try RING DELAY, RING TIME, NUMBER OF RINGS TO ANSWER , or any other settings relating to how your fax answers the phone line. Try changing each setting, one at a time, and try calling your fax to see if it answers. There may also be settings on your fax to set it up if an answering machine or telephone is on the same line.
    Jul 17, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    Can't send or recive Faxes
    Try resetting the machine to it's defualt settings.
    Jun 18, 2008 | HP Photosmart C6100 All-In-One Printer
    Phone line and fax line
    If you actually have a 2 line setup with 2 #'s each with it's own separate line, it's wired backwards. Otherwise (distinctive ring, etc) the machine has to be capable of and set-up to recognize which ring pattern is a fax call.
    Also, you have to enable auto-answer on the fax machine.
    Feb 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    Fax picking up the main Line
    YOU ACTUALLY NEED TO USE DRPD MODE WHICH IS IN FAAX SETUP  AND SET IT TO THE TYPE OF RING PATTERN YOU HAVE ON YR RINGMASTER SYSTEM.
    IT WILLL START DETECTING THE RIGHT TYPE OF RINGPATTERN FOR FAX MODE ..
    HAPPY USING SAMSUNG AIO
    OMNIPRESENT
    Sep 11, 2007 | Samsung SCX 4521F All-In-One Laser Printer
    Lexmark X7170 All-In-One InkJet Printer Logo
    108 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
