Question about Samsung SyncMaster 17 in. LCD Television
VGA signal dim
The vga signal on my screen suddenly has become very dim. All the other functions of the monitor are the proper brightness including the onscreen menu in pc mode. Can anyone help? I don't know if it is the cable or the screen or what. It has done this on a pc and a mac. Thanks, Jonathan
This seems to be a known issue with the 170MP monitors. Last time I contacted Samsung they seemed unwilling to replace this model. I took my screwdriver to it to no avail (only reseated an IC). The only solution I've found is jury-rigged at best: Enter the OSD, PC Settings. Third tab from the left is "Color Control." Selecting User Mode here, you can move all the color sliders from 50 (default) to 100. You'll get a minor (in the long run, barely noticable) rise in brightness. Whatever the root cause of this failure is, it's too deep for me to find on my own. Considering previous (read: warrantied) repair orders resulted in a new/refurbished monitor being sent to me, it's possible that we as consumers are unable to resolve this one.
Posted on Jun 14, 2007
    Champion:
  • 217 Answers
I would try another cable first
Posted on Apr 01, 2007
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
Screen goes dim and bright
have you checked the connections on your VGA cable
sounds like the cable is either on its way our or not getting a good connection make sure all screws are tight if this doesnt work might be worth borrowing a cable if you can before purchasing one just in case its the monitor that is dying
Dec 14, 2011 | Dell Computers & Internet
Acer x136w monitor, no signal. Connected parralel conector to back of computer. no signal..tried everything I know to do. Even stupidly pirchased driver whiz. nothing. ready to through monitor into th e...
No signal message on your LCD monitor screen means that your monitor is not receiving any signal from your PC graphic card. This problem "no signal" have nothing to do with the drivers installations. Have you check whether your graphic card is faulty or your cable connection properly connected/secured? ie VGA (D-sub). As far as I know there are no parallel connectors for PC Monitor connectors only, VGA(D-sub), DVI or HDMI cable interface.
Try to connect your monitor to another PC, just to test whether the LCD monitor is functional.
Hope it helps.
Mar 19, 2011 | Computers & Internet
Moniter keeps turning off saying no video imput
Hello and Welcome to FixYa!
Check that the Input signal cable is properly inserted in the VGA socket. Secondly the Primary VGA is properly giving display signals to the Monitor/LCD. Because there are cases in which VGA is the bottle neck of the trouble you are facing.
Cross check and update me with the status,
Best of Luck,
Do RATE the solution, If found Helpful,
Concerned.
Jun 13, 2010 | HP vp17 Monitor
Using my hanspree jm01-22 through vga cable alls fine except lack of brightness on the screen,ive turned the brightness and contrast up on the monitor and its still fairly dark,appreciate any help
It does sound like it had logic issue that seding the dimming command to the backlight inverter circuits to dim down the lamps. Yoy may have to look inside.
Please look here to see what ususlly goes wrong with the monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 31, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
My monitor screen has become greenish and with
Hello Devsi, hi, check your VGA cable connection for loose connections, try tighten it first to see if it solves the problem. the greenish thing is cause by a missing red signal, and the distortion is caused by a missing horizontal sync signal, also check out if there are bent pins on your monitor signal cable. just unplug the VGA cable and see if the pins are in order. if bent, carefully straighten it with a slim slotted screw driver.
Dec 17, 2009 | LG Flatron L1750S 17" LCD Monitor
Black screen on acer 242lc lights come on power up
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 18, 2009 | Acer TravelMate 242LC Notebook
Sudden color distortion
this can happen if there is a poor connection of the VGA cable - tighten the screws on both ends, just in case one is loose
Dec 28, 2008 | KDS K22mdwb LCD Monitor
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Samsung SyncMaster 17 in. LCD Television Logo
116 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
