Question about Denon Dns1000 Table Top CD Player CD Player
Help with denon dn-s3000
My s3000 will not play cd's, it keeps sayiing disc error...what should i do?
thanks,
jeremy
  • jason May 11, 2010
    do you have a multi brush cd/dvd laser lens cleaner?
    can you open it up?
    Problem Solver:
  • 17 Answers
CD lens cleaners are not to be used with these slot load cd players (as per the manual).
Please visit www.denoindjforums for further help.
Posted on Mar 10, 2009
  • 905 Answers
If the cleaning cd don't work then it will need to be cleaned by hand , and if that don't do it then you will need the laser mechanism replaced
electech
Posted on Oct 31, 2008
No disc error dvd on Harman BDS
maybe try cleaning the laser ? with a cotton wool bud and metho
Jul 28, 2013 | Harman Kardon Audio Players & Recorders
Denon DN-C635 CD Player problem.
In working with consumer electronics a lot of years, the pickup, mechanism or CD section is not always at fault but people that
are trying to work on their own equipment make assumptions that may not be correct. If you put in a new CD player then the other issues as with all wave soldered equipment can be bad solder joints and even bad solder at joints where the connectors are as these get a lot of activity in a repair. Look at the PCB well. I have fixed a lot of equipment by resoldering bad or broken joints. Check around power transistors and those larger drive transistors for these broken joints.
Mar 22, 2013 | Denon DN-C635 CD Player
I get disc error when inserting a disc into my Denon DN S700
Are you using the correct format of discs? It requires Standard compact disc (12 cm), types CD-TEXT, CD-R, CD-RW (CD-R and CD-RW disks must be finalised before using - but even then will not always be accepted) It will not work with CD+R or CD+RW
If it will not work with ANY CD (including professionally produced CDs) then the lens may need cleaning. Purchase a CD cleaning disk (a computer CD cleaning disk will work fine) pop it in the slot and hit the play button.
You can download the manual here http://www.denondj.com/Assets/Dimages/Products/Manuals/ab8715a8c0d742f0ab8c9afed5bf90e0.pdf?ts=012725
Feb 08, 2011 | Denon DJ DN-S700 Compact Tabletop CD/MP3...
1996 ford explorer with JBL sound system with 6 CD changer, keeps saying BAD CD when asked to play
Welcome to Fixya
Try to use cd cleaner first to clean the lens. Its giving you a BAD CD error because the lens cannot read the disc. Do the cleaning method 2 times.
Please reply to this email for any update.
Thank yuo for using Fixya!
Jan 03, 2011 | JBL MCDC100 6-Disc CD Changer
My cd player keeps on saying error
run a lazer disc cleaner through it serveral times
Jul 03, 2010 | Sony CDX-656 10-Disc CD Changer
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
Denon Dns1000 Table Top CD Player CD Player Logo
360 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
