Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
No Power in Monitor
I had the same problem last night with my Dell Monitor. Hooked monitor up to a brand new Dell system , still same problem. I took a 6 yr old monitor from Dell and hooked it up to my system and it works fine. I have zero power, the light stays orange and will not shut off even though I shut the system down totally. I worked on this for an hour with no luck. Any suggestions beides the garbage can? Thanks
    Scholar:
  • 94 Answers
If you are a tech. Check the voltages going to the Logic Board, if one is missing (12 or 5v. Then that is most likely due a an IC failure on the power supply board. IC 901 Don't quote me on this, but I know it is less than $10. Sorry, I only have 1 left, the last one I did was in Aug2006 so memory is fuzzy. Kegtapper
Posted on Oct 13, 2006
Dell Monitor wont turn on.
Your monitor has a self-test feature. Have you tried using it? The link below will give you directions on how to do this. It will also give you information on common problems.
http://support.dell.com/support/edocs/monitors/E176FP/En/index.htm
Jun 03, 2010 | Dell E176FP 17" LCD Monitor
Took the tower in for update and when I hooked it back up there is no screen display - monitor is not working
Check your connections again and make sure monitor is plugged into power and is turned on.
Oct 01, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Out of the blue one day, monitor started displaying "anaolog power saving mode." This is a stand-alone computer which has never been hooked up to internet.Took tower unit to PC World to see if it was a...
you go to control panel starting your pc ,, then display settings,, from there,, screen saver tab, then make screen saver to none, and click on button power,, there you make everything to never,, and then see. it should work good
Sep 27, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 22, 2009 | Samsung SyncMaster 920NW Monitor
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
My flatscreen dell monitor fades out to dark gray, sometimes pink
Its definetely the monitor thats having a problem. when it blacks out during th monitor self test. i suggest you can ask for a replacement monitor.
Mar 19, 2009 | Dell E193FP 19" LCD Monitor
Dell m992 crt monitor
If it's getting no signal, make sure the monitor is set for the correct input. This would be either analog (if your cord has blue ends) or digital (if the connectors are white). Depending on wt yhat your monitor is, a button on the monitor will help you set that. If it's set for the correct input signal, then switch out a different cable to see if perchance you have a bad cable out of the box. If there is another PC or laptop setting around, plug your monitor into that to make sure it's good and maybe even plug THAT monitor into yours to make sure there is nothing wrong with your video card. Let me know what transpires. If this takes care of things, please help me out by rating it accordingly.
Jan 13, 2009 | Dell M992 19" CRT Monitor
I have to press the power button 4 times on my monitor before it works
well i think there is problem with ur screen on/off switch and its technical problem just take it to the service centre. and u might wanna check the power cables before that it could be loose and ur signal cable to.make sure its hooked with ur system tightly .pleasure helping u .
Oct 24, 2008 | Dell E153FP 15" LCD Monitor
Black screen on LCD Monitor
There should be an problem with your power card or please change your monitor immedietely...
Jan 01, 2008 | AOC LM729 17" LCD Monitor
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
291 people viewed this question
Alun Cox
