Question about Abit NF-M2S Motherboard
Boot off IDE with SATS drives present
All worked fine with 2 SATS drives.
Now I have added an IDE drive and tried to boot off it and I get a quick flash of blue screen and reboot.
If I boot off the SATS, I see the IDE drive just fine.
Please advise,
Thanks,
Mark.
  • marc12205 Oct 29, 2008
    that's SATA drives - TYPO !
  • 781 Answers
I tried to put ide with SATA and got the same I think IDE and SATA do not mix unless you know how to set up.
Easiest and cheapest in long run use one type of drive
Posted on Oct 30, 2008
I have a Windows Server 2003 system on a old Dell desktop. I want to move it (hard drives) to a Systemax Venture.
You need an IDE controller board to boot from. The SATA drives have not system on it only data, so it cannot boot from these drives.
Oct 01, 2014 | Systemax Computers & Internet
Secondary ide won't detect HDDFoxconn 915 P7AC
Try putting both secondary channel Hard drive jumpers to cable select to see if that doesn't cure it
Feb 20, 2014 | Computers & Internet
GA-EP41-UD3L problem with SCSI/IDE
Sounds like the motherboard bios is only capable of booting from drives connected to the motherboard's ide connector and not additional / or external ide connectors. Looks like you would have to have 1 HDD and the CDRom Drive on the built in ide connector and the other hard drive on the extra ide connector you added. Although that would probably stop the other HDD from booting. Have you thought about putting both operating systems on the same drive. I do it all the time.
Feb 11, 2012 | Computers & Internet
I have installed windows 2000 server and i am getting problem in booting of os. when there is cd of ms2000 present in the cd drive the os boot properly while if i remove cd from the drive and start the...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Apr 15, 2011 | SuperMicro X6DVL-EG2 Motherboard
Adding ide drive to a sata boot p4p800x xp Problem - ASUS P4P800-X Pentium Motherboard the system would not find ANY boot device
GaRoMo, 2 things. One change the pin on the IDE to a slave. Two open your bios. Asus board press the delete key every two sceonds untill the bios main menu opends. Go to BOOT section & make sure you have the SATA drive to boot. Your IDE should not be listed. Thats it.
Mike
Apr 25, 2008 | ASUS P4P800-X Pentium Motherboard
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
How to format SATA drive
Hi, the setting will be in the BIOS menu. switch on and hit F2 or whatever it is for your motherboard (it should say on screen). then go to the HDD settings and enable SATA
Feb 20, 2008 | ASUS P4V8X-X Motherboard
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Abit NF-M2S Motherboard Logo
94 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
