Question about Canon Rebel XT / EOS 350D Digital Camera
CF Card Err
I took phots with camera, took out CF card and had photos processed. When I tried to put CF card back into camera, I get a CF Err message. I went to Radio Shack and tried a new CF card but I get the same CF Err Message. What should I do?
Sounds like you have bent pins on your CF reader. Open the door, take out the card and look inside. Is there damage to the pins?
You maybe able to fix it with pincers and a needle just align the pin or pins that are out of place, i did this and it worked for me and now my camera is working fine. and for free.
Good luck
Mattias
Posted on Dec 23, 2008
  • 489 Answers
Hi
Sounds like you have bent pins on your CF reader. Open the door, take out the card and look inside. Is there damage to the pins? If so you need to replace the CF reader.
If you can solder really really well you can replace it yourself, we have the part available in our store (Google: Darntoothysam) Im sure Canon will want $200+ for the repair, and we are not currently offering to do the repair for customers, sorry.
Good luck from Darntoothysam com
Thomas
Posted on Nov 01, 2008
Error 99 keeps coming up I reload the battery turn on off but after a few shots it comes up again and the red shows indicating that it is still processing the shot.
Here is the diagnostic process, allegedly from Canon themselves. It's quite old, a newer camera probably has a SD card rather than CF.
To isolate the cause of the issue, we [Canon] suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the camera should be serviced.
Jan 19, 2011 | Cameras
I took my CF card out to get photos, went to put it back in and the screen read "There is a problem with CF card. Replace the CF card." I didn't think there was a problem with the card. But I replaced...
Your CF pins in the camera are most likely bent/broken. This is a very common problem. Most repair shops will charge $150-$200 to repair this.
Hope this helps.
Wes
Sep 10, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Error reading on screen on 1000e
Hello :
Here is what Canon said according some forums :
To isolate the cause of the issue, we suggest that you do the
following:
steps:
camera body.
I hope this will help .
please don't forget to rate !
Apr 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
I keep getting error 99. I've cleaned the sensors with a new eraser; I've changed the battery and changed the memory card. If I take out the battery and put it back in, I can take a picture. If I pause for...
Hello:
following:
steps:
camera body.
Mar 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Rebel XS ERR99
This is something I found when googling your problem.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
following:
steps:
camera body.
May 25, 2009 | Canon Cameras
ERR 99
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Apr 11, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Error 99
camera body.
Jun 28, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
CF Error
I had the same symptoms. I took it to an authorized Canon repair shop. For $150, they resoldered connections on my 'power supply board'.  No idea why the solder gave out. It's working great now.
Jul 09, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
427 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
