Why does my philips dvdr3380 eject tray says blocked which prevents me from opening the tray
Does the blocked icon appear on everything that you load?
Posted on Oct 29, 2008
Dont know i have this disc which i downloaded from the net cos my dvd player is divx was playing up for a while then refuses to open have tried switching off for 24 hours then reboot but no joy this is very frusrating and will never buy from philips again
CAN'T EJECT, IS BLOCKED
I had the same "Blocked" problem and solved it - by using a rubber band! Unplug the machine and take off the outer cover. Remove the DVD reader and take off the cover to the reader - you can now easily recover the DVD that was stuck in the machine. Now slide out the actual DVD tray, you will have to bend back a couple of restraining bars to get the tray out completely. You should now see a small white wheel which is actually the end of a concealed electric motor. There will also be a larger black pulley which controls the movement of the DVD tray. If there is no band connecting the pulley and the white wheel, that is your problem and I solved it with a small elastic band. Put everything back and turn on, wait for all the messages to clear and press the eject button - the tray opens simples. It has taught me never to force the tray in manually, but to always use the eject/open button.
Oct 26, 2010 | Philips DVDR3380/05 DVD Recorder
Philips DVD 723 . the tray is not opening. blocked message comes.
There will be a slotted hole on the underside slide a screw driver across this will manually activate the tray dogleg and will part open the tray for you.
Dec 05, 2009 | Philips DVDR3380/05 DVD Recorder
When i press to eject it does not open
There is a manual release underneath look for a slotted hole near the front slide this across with a small flat head screw driver, this will release the tray.
Oct 31, 2009 | Philips DVDR3380/05 DVD Recorder
In Philips DVDR3380/7 I need open for put DVD it say "blocked" permanently, which is the solution?
This will happen if you close the tray by pushing instead of using the insert/eject button. the BLOCKED error means the the rack and pinion can't be moved by the motor which takes too much current and stalls hence the error
The guide pin can jump is dogleg and cause the tray to bow slightly this can also cause UNKNOWN DISC as the head tries to read the DVD at an angle.
The best option is to free the tray UNPLUG and remove the cover the you will have to remove the inner cover on the top of the DVD mechanism you maybe able to see the tray bowed look underneath you should see the dogleg guide and the pin should be inside this track yours might be outside, try to re-seat don't force it or pull the tray out you may not get it back inside the unit.
With the cover back on test the eject if this still wont work there is a manual release on the underside of the unit which is clearly visible place a screwdriver into the hole and slide across to release the DVD. This model has not release hole at the front as kladdaugh suggested this paperclips type of release is normally put onto ATAPI DVD-ROMs on your PC
Oct 22, 2009 | Philips DVDR3380/05 DVD Recorder
MY DVDR3380 TRAY WILL NOT OPEN, SAYS ITS BLOCKED
Aug 22, 2009 | Philips Televison & Video
3380 recorder cannot open tray says blocked
I had one just the same it appears to happen when the unit has been left on standby for a long while, on old players, and if you close the tray by pushing on the front instead of using the open button.
However, you can normally get the disc out if you press the eject key about 5- 6 times in quick succession. This is only a quick fix and the route of the problem lies inside. I think your player has a micro-switch that is on its way out. If you open the unit you can short this switch prevent the blocked message but this is a bit drastic.
Time for a service me thinks.
Aug 08, 2009 | Philips DVDR3380/05 DVD Recorder
Unknown disk type
Press 'Disc Menu' and wait for 'no disc' to appear on the screen. Eject the tray by pressing the 'open / close' button on front of the recorder. Enter the following numbers very slowly on the remote control ' 0086000 ' Press ' OK ' button on your remote control. Close the tray by pressing ' open / close ' button on the front of the recorder. You can check this has worked by pressing ' 0009 OK ' on your remote after the tray has closed. A display will pop up on screen showing the Region as 0. This means you should be able to play discs from all Regions. If this doesn't work the first time! try again! Hope this helps!!
Jan 24, 2009 | Philips DVDR3380/05 DVD Recorder
3370 H player is 'blocked' cannot eject disk
Hi there, try tapping it lightly with your hand just above the tray and then press eject button!! It works everytime with my one!! Hope this helps!!
Nov 01, 2008 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
479 people viewed this question
Top Televison & Video Experts
