Question about RCA RP-9380 Boombox
Tape Player The doors of my two tape player compartments won't close.
  • 1056 Answers
SOURCE: On the RCA cd player - how do I record from songs
Using RCA cables just hook up the RCA cable to where it says "input" to the one doing the recording, and hook up to RCA cable to the one plug where it says"output" on the one thats gonna do the playing. Red cable goes to red, white to white etc.
Posted on Jun 30, 2009
0 characters
1 Points
Sony personal audio system boombox ZS-D55 Malfunction
The disc loading mechanism has the fault. Might be a loose or brokent loading belt. Check it.
May 02, 2012 | Boomboxes
Cd player only shows
You will need to check the swith that change from Tape to CD to other functions. If the switch is good. Then the next thing is to check for tape function. Can you try to fast forward, reverse. If these functions are working properly then the pinch roller ( the little wheel that is pulling the tape need to be replaced). If nothing moves then you need to replace the belt and the wheel and possible the motor at the same time
Nov 17, 2011 | Lenoxx Electronics CD-102 Cassette/CD...
When i buy sony cassette tape, it records good on just one side of a cassette. the other side rather outside mic or inside off radio is very low almost impossible to hear up close.
Check and clean the mechanism parts of your casette player mechanism. Look whether there is dirt accumulated on the capstan shaft and pintch rollar of the mechanism. This is the main cause of tape slip and irregular output from it. OK.
Sep 22, 2011 | Philips Magnavox MCS225 17...
How do you start a tape to play ok..i turn on...put in a, how do i get it to play
Look for a symbol that looks like this >I. or just this>, and push. Make sure you have selected "tape" function
Apr 10, 2010 | Sony Boom Box With CD Player & Cassette...
Durabrand Tape/CD Player twists up all cassettes inserted
We have two of these with the same problem. The belt that drives the pick up reels is broken. We are trying to find a place to purchase new ones.
Mar 26, 2009 | Durabrand CD Player with Cassette...
When I press play, my tape player eats the tape.
that means that the uptake wheel is not turning. typically this is caused by a rubber band that is insde the transport mechanism that connects the motor to the wheel.
if you are comfortable taking the device apart, you will need to find the right band and just pop it on.
Mar 16, 2009 | Sony Boom Box With CD Player & Cassette...
I need information on how to operate a tape in my machine. I can insert the tape, and push the button to start it playing, but the tape does not play. Which of the 6 buttons will get the tape to play?
My solution was to get my son to e-mail me the list of instructions that I couldn't find with my machine. The instructions, although vague, were very helpful!
Jan 06, 2009 | Sony Boom Box With CD Player & Cassette...
Sony CFD-E95L disassembly
There are 11 screws that need to be removed: Bottom - 2 on both sides of the word "ATTENTION"; 2 on the outer edge at the three and nine o'clock positions; 3 under the handle; 2 in the CD player compartment; and 2 in the upper left and right corners of the cassette compartment.
Feb 04, 2008 | Sony CFD-E95 Radio/Cassette/CD Boombox
Boomboxes Logo
Top RCA Boomboxes Experts
Jonathon summesfield
Are you a RCA Boombox Expert? Answer questions, earn points and help others
