Question about Microsoft Windows Vista Ultimate Edition
Error code 1012
I try to install recovery disc at the begining appears error code 1012
  • 76 Answers
Add/Remove Window components
Im not sure which file you are referring to but you could just a repair of the installation
this is fot the master boot record
if there are any other files , settings or programs during the repair process options for these should be available
Insert your Windows XP installation CD or recovery disc, and restart the computer.
Instead of attempting to boot Windows as it normally would, the computer will give you an option to boot from the CD.
Press a key when prompted, then wait for the setup program to load.
Press the "R" key on the "Welcome to Setup" screen.
This will cause the CD to launch the Recovery Console instead of attempting to install Windows XP on your computer.
If you have an administrator password on your copy of XP, then you will need to enter it in order to log in to the Recovery Console.
Choose the installation of Windows XP that you want to repair (generally the only option). Wait for the command prompt to appear, then enter "fixmbr." Press "y" when prompted to let the FixMBR utility overwrite the corrupted bootloader with a new copy.
Remove your XP disc or recovery disc, then type "exit" into the command prompt.
The exit command should cause the computer to reboot, allowing the computer to load the new bootloader file and then continue Windows XP startup as normal.
Hope this helps
Oct 30, 2012 | Microsoft Windows XP Professional
Solutions for "HP Pavilion dv5
File: \BOOT\BCD Status: 0xc000000F Info: An error occurred while attempting to read the boot configuration data. First try going into Windows safe mode with command line utility enabled. (F8 on bootup). In command console typechkdsk /f /r and enter Y for yes at the prompt. Wait for it to finish, it may take a while and then test the issue. If the problem persists, please continue with the following instructions. Rebuild BCD 1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. (Click the operating system that you want to repair), and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type BOOTREC /FIXMBR, and then press ENTER. 8. Type BOOTREC /FIXBOOT, and then press ENTER. 9. Type BOOTREC /REBUILDBCD, and then press ENTER. Use the Windows Recovery Environment (WinRE) to run System Restore 1. Insert the Windows Vista installation disc into the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time and currency, and a keyboard or input method, and then click Next. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next 6. At the System Recovery Options Dialog Box, click on System Restore. 7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point. 8. Click Finish to restore the system. Startup Repair from the Windows Recovery Environment (WinRE) 1. Insert the Windows Vista installation disc into the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time and currency, and a keyboard or input method, and then click Next. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next. 6. At the System Recovery Options Dialog Box, click on Repair your computer. 7. (Click the operating system that you want to repair), and then click Next. 8. In the System Recovery Options dialog box, click Startup Repair
finaly if you do not have the cd you can use a copy too.
Kronoguy
Jul 04, 2011 | Computers & Internet
Everytime i boot my Toshiba Satellite L305D i get a message on a the black screen before windows startup saying "windows has encountered a problem communicating with a device connected to your...
If you have external USB and/or CD disconnect them and try again. Otherwise it could be a fault hard rive - try to boot from an emergency CD (hopefully you created one when you installed Windows).
May 11, 2011 | Computers & Internet
Error how to i fix 0x400110020000100A
I think your recovery discs are corrupted. if this happens (0x400110020000100A) again and again you will need to buy new recovery disc.For next time try to make the recovery disc in DVD because if u make in CD there will be some possibility to be corrupted--- Good Luck
Oct 07, 2009 | Microsoft Windows Vista Home Premium with...
Cant do a factory reset
Use the CD's that came with the PC re-install the OS and then re-install all other drivers and software that came with the computer. If you need any specific instructions please fell free to ask.
Ryan Frame
Creative Energy Associates Technical Center
Aug 30, 2009 | Computers & Internet
CD/dvd drive disappear/will not play
Go to Control Panel and uninstall the program you installed (CD/DVD) installer. Reinstall the program.
Jun 20, 2009 | Microsoft Windows Vista Ultimate Edition
Bought a computer requires password
What you have purchased is a computer that was on a network. Ctrl+Alt+Del is the normal way to login to the network.
I don't think you have much hope of getting in without a password.
My only suggestion is to reboot and watch the screen to see if you can access a recovery partition. Watch for a message that says Press F2 or some other F key to run recovery. Press it and do a full recovery.
If that doesn't work, tap F8 repeatedly as it begins to boot and see if there may be a recovery option from the menu that appears.
Final option is to purchase a new OS and install. (Try eBay.)
Nov 02, 2008 | Microsoft Windows XP Professional
Installing adobe software..got error code 1012 on mac 0sx 10.1
what type of computer are you using. a new one? if a new one you can't work it out due to some software instruction of the old version are being deleted or refined to increase the working capability.some of the code have been change.
Dec 27, 2007 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
118 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
