Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Canon Powershot PD630 will not turn on!
Help!
my camera wont turn on! i have charged the battery and even tried someone elses battery, but still wont turn on!
  • 489 Answers
Hi
Either the fuse has blown or there is another problem with the main PCB or possibly the battery door indicator switch.
Open the battery door, by the memory card slot is a tiny switch; is the black tab for the switch still there or is it broken off and missing? Is it jammed down? Try holding the switch down with a pencil and press the power button... does it work?
If it doesnt seem to be the switch, it's probably the fuse. If you can solder well you can probably replace it yourself, and I will get the fuses tracked down and listed in the store so they are available to anyone who needs them.. they are cheap!
We are a digital camera repair business, if we can help please let us know! Good luck from Darntoothysam com
Thomas
Darntoothysam com
Posted on Nov 01, 2008
Camera wont turn on
Couldn't find a firmware upgrade for my PowerShot A720. Tried putting a piece of rubber under the spring on the lid to make it tighter and it helped because I can take more pictures before I get the dead battery message (even thought they aren't dead). I bought the Duracell that you can check the charge on because I'm sure I've wasted dozens of batteries by now.
Jul 30, 2013 | Canon PowerShot A720 IS Digital Camera
My canon rebel t3i won't turn on after I charged the batteries and this light kept turning on but now the camera won't even turn on .
First try a different battery in your camera.
second try your batteries in someone elses canon (same model)
third go to some one that can check the battery.
Has the camera got wet at all? if so then ther might be internal damage and need to be serviced
Jan 12, 2013 | Cameras
I have a Canon powershot A1100is dig camera. When I try to turn it on, it reads need new batteries. even if I change the batteries. Sometimes it wont even turn on. Help
Do you using Ni-MH batteries? Canon cameras judge the battery is low power by the real-time voltage of the batteries. And the voltage of Ni-MH batteries are lower than Li-ion ones, so the camera will notice low power even there are new batteries. Try Li-ion ones and see is anything help. best wishes!!
If you will use of a special battery, please come to our online shop for digital camera batteries
Feb 21, 2011 | Canon PowerShot A1100 IS Digital Camera
SD750 not turning on
Did you reolaced battery that evening, if you did then try holding the battery door tight and the turn it on. If this will solve it it means that there is a play in battery door that happens very often if someone is not careful enough while replacing battery or merory card.
Sep 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Cannon Powershot A720 IS, wont turn on.
Where do you live? Look up Canon on your computer and find out where they are located. The nearest one to you.
Jun 09, 2017 | Canon PowerShot A720 IS Digital Camera
My canon powershot A530 WONT TURN ON!!!!
Check the batteries, and if they are bad, replace them. If it has rechargable batteries, just get rid of them and try regular alkaline batteries. That should be the fix.
Oct 05, 2008 | Canon PowerShot A530 Digital Camera
Help
Wow, this is trully amazing. I went to do a search on why my camera wouldnt turn on the past couple of days, even after i charged all THREE of my batteries and found similar complaints within the same time frame!! WOW. We need to get together and fight this, cause its suspect!!! I bought mine in Mass, anyone else?
Jun 30, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Won't Even Turn On
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Feb 16, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
145 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
