Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Green screen with almost horizontal zigzag lines
When I power on my KV-27FS100 I find green screen with almost horizontal zigzag lines. If I turn the tv off/on I see bright horizontal beam and within seconds whole screen turns to green with whiter lines. If I slap on top-left or top-right side picture comes perfectly and stays as long as I keep the tv on. As soon as I turn off the tv and turn on after 10-30 minutes , same problem happens. Also when the picture is ok, I see the right side color is distorted. What could be the problem?
  • fazil finn Sep 08, 2006
    Thanks jomaru for your help. I checked the complete chassis for loose conections for more than 2 hours but couldnt find any loose connection. Where should I look for the problem?
    Sergeant:
  • 337 Answers
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Posted on Sep 07, 2006
  • Omar Urrutia
    Omar Urrutia Sep 14, 2006
    Loose Conections are very easy to find if you know what they look like,some are hard to find even to trained technicians.The symptoms point to the Horizontal drive circuit but I would check everything after I have found and corrected the problem.The simple fact that it reacts when you hit it and the pix comes or goes as you do it tell me something is loose,I suggest you call someone qualified to find it and resoldered the board,the problem is not visible from the top of the main board and you need to see close to the soldering points.Be safe call someone should not be too expensive.
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Blinking
hello
It sounds like it is trying to start but is unable to.
these sets have bad horizontal output transformers.
you need a tech to solve this one.
Thanks Guy9
Jun 22, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
TV screen turns green
i think your color combination chip is not working. you may have to change the chip of color system.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Connect Apple TV to Sony 27FS100
the kv27fs100 is a standard 480i resolution check the output of the apple tv make sure it is not in progresive 480P
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Hello im having problems with my sony wega
It sounds like you have a loss of green. This could be caused by the green gun in the picture tube opening up or the drive circuit for the green gun gone bad. Stargazer
Aug 10, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
350 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
