Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Subwoofers I have 2 12" l7 kickers and i was driving down the road yesterday when i turned it down at the drive through and when i turned them up on my way out neither of them hit at all, all other speakers work fine the amp is a 2 channel 1200 watt lansar viberant i have it bridged i know the amp is turned on and ive checked every wire in my car and they are all hooked up right i even took the subs out of the box and checked the wiring their and its fine. Iam baffled and really hope that im not out $400
Sell me the subs it would be better
Posted on Nov 19, 2008
When i turn my two 12" kicker l7 up they cut out
You could be having an amp overload condition. Make sure your speaker impedance matches the amp specification. Esp if you have bridged the Amp the impedance should be at least 4 Ohms and not below. When you connect two 4 Ohms speaker in parallel the total impedance becomes 2 Ohms !!!.
Sep 26, 2011 | Car Audio & Video
@aol.comI have a kicker zx 1500.1 amplifier and a 15 inch L7 2ohms. Is the amp too much for it?
the amplifier is never to much for the sub. If the gain on the amp is turned up to much then that will pop the sub.
Jul 30, 2011 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have a 2008 kicker l7 15 and it hits fine when the volume is mid range but if i go up on the volume it makes this poping sound the amp is tune down
You need to turn DOWN your LPF....(low pass filter). You are driving the sub with a higher Hz than it is rated for. If your amp (or head unit) doesn't have a good LPF, then you are going to do damage to the sub over time.
Please rate if this helped!
Apr 06, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have a brand new L7 is it blown?
check to make sure your box is securely sealed and that the box itself is not rattling. if not, most subs require a break in period where they can not be played full gain/full volume for the first 48 or so hours... did you break in your subs by paying it softly the first day and slowly turning your amps gain and receivers volume up the next couple of days. if not, it is likely blown
Oct 07, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Db drive vs kicker
The Kickers are the way to go here- they move more air because naturally a 15 inch square has more area than a 15 inch circle- thus more air moved =greater spl =LOUDER. The only thing that might get some equality between the two is if the db drive round sub has a far greater xmax that is the linear movement of the cone from start to full excursion-IF the db drive has drastically larger xmax than it could possibly outperform the L7 because of greater cone excursion which also =more air moved=louder---- haha thats a tricky one but ya got me wondering too so let me know what you find out please-Ive always been a kicker fanatic so im probably biased towards their products-never heard nothing bad about db drive though either im in salt lake city i dont know of anywhere out here that even carries their products so i have nothing to reference by except kicker L7's kick asssssssssss
May 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
2 12" kicker L7 subs. zx1500.1 amp. subs quit when i turn it up
It is possible that you are not providing enough current to the amp. It will go into protect mode if the current sags. What do you have running as a power cable. And also, your ground should be just as big and bonded very well to the body.
Apr 12, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
The speaker keeps going in and out
Does it go out when the bass hits or just whenever?
Mar 14, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I turned my 15" L7 kicker and smoke started to come out the box
As stated before, knowing the impedance of your subwoofer would really help the situation. Either way the link I have provided is to your subwoofers manual (Incase you dont have it)
But since you have said it has smoked, if it still works I recommend turning the bass boost down (Bass boost causes alot of heat within the subwoofers voice coil and even within the amp itself and should never be maxed out.)
Here is a link to your manual for the subwoofer.
http://www.kicker.com/sites/default/files/SoloBaricL7Series.pdf
So as a solution to your issue, keep your bass boost turned down. You should almost never need it if you have tuned your amp correctly (You have a very serious subwoofer there)
Consider yourself lucky if your subwoofer is still working without issues.
Feb 09, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
129 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
