Question about JVC DRM10 DVD Recorder
Mysterious "ring" on burned DVD causes playback to freeze.
Close inspection of the surface of a burned DVD containing several .avi movies shows a thin ring which causes only the first movie to freeze sometimes during the first 30 minutes of playback. It has occurred on different DVD brand media and on various software such as Nero and Roxio. I find this happens on about 20% of the discs I burn. Is this a common problem with burning DVDs? Or is something wrong with my hardware?
    Problem Solver:
  • 5 Answers
Is the image preponderantly encoded in PAL? Majority PAL and some NTSC? Or fully NTSC? Used transcoding presets? Transcoded project before you built to DVD? Note: Always run "TEST" before burning (to save plastic trees)? Determined whether system or project is faulty? Tested the DVD drive? Tried burning using another application? Closed all background-running resource hogs and applications? Did the project size increase the capacity size of the disk? Used a lower write speed? Disabled startup items and services? DMA: enabled? Updated Windows? Media compatibility? System requirements attained? Updated your application? Solved the issue(s); then write it down and share it with others. Still having issues? Revert back to the computer's factory settings and rebuild, upgrade, or invest in a high-end system and buy the full version of Nero 9, with all the plug-in features....and so forth. If time is money, the latter solution is your best bet. If money is an issue, then it requires trench warfare - that is, much research, deductive reasoning and time investment to isolate your specific problem...start by analyzing your source, and then your target...cause/effect relationship...you'll conquer all problems, eventually...political machinations aside. Ye all be happy computing Chomskyites. Dr. Frank Kohnstein.
Posted on Jan 12, 2009
Playback prohibited by area limitations - what does this mean?
you are trying to use a dvd from a different region then the player is set up for the player has to be unlocked to play multiple regional discs
Jul 17, 2011 | Sony DVP-SR200P DVD Player
Tip
Tips: How to burn AVI files (torrent/digital Camera videos) to DVD on Windows 7
Do you like to shot videos with your favorite digital camera to capture and keep every happy moment in your life? And do you never miss any movies which can be free downloaded from torrent sites, such as Pirate Bay, Vuze, etc. to fully enjoy digital life? That's wonderful digital experience, but to keep these movies and life memory forever is suffering, isn't it? 'Cause either your digital camera's memory or your PC hardware has a limit, so many digital lovers keep asking how to burn digital Camera/torrent files to DVD:
Q1: My torrent downloads are always in the .avi format. I would like to play these movies in a regular DVD player, but I don't know how to burn the DVD on my computer (running on Windows 7).
Q2: I've shot the movie myself using a camera, it is a two hour long .avi file. All I want is to be able to shove it in the DVD player (in the living room) and for it to automatically play.
A: That's true, most videos shot by digital camera, and most free downloaded movies from torrent are in AVI formats. A good and easy way to keep these videos and movies forever is to burn AVI files to DVD which makes easier for you to watch these videos on your DVD player without any hitch. That's easy to finish the whole task, first of all, let's look at all the things you will need to burn AVI movies to a DVD.
1. Things You'll Need to burn AVI files to DVD AVI to DVD Burner software
A black DVD disc
A PC running on Windows OS (including the latest Windows7)
A PC with DVD Burner
2. How to find a good AVI to DVD Burner?
Actually, there are a lot of AVI to DVD conversion software, please never get a one without free trying first. Before making a purchase decision, you can get recommendations from professionals, friends, etc. And the most import thing is to get a free trail by yourself. In fact, I have tried a lot of such software, but for the sake of simplicity and stability, I will present you such a conversion tool which works well to convert AVI format to DVD on windows 7.
3. Steps to burn AVI files to a DVD on windows 7
Step 1: Free download AVI to DVD Burner
Please free download this Windows 7 AVI to DVD Burner, install and run it. And insert a DVD disc to your PC.
Step 2: Add AVI files
Add AVI videos or movies by clicking "Add Video" button.
Step 3:Set DVD menu
Select your AVI files, then hit "Burn DVD" button at the bottom of the interface, and then check "Next", you can select DVD menu from built-in "Menu Template", and you can set background music and picture for your DVD menu by checking the related option to customize your DVD menu. Here I set the background picture by adding a picture from your PC. If you want to preview your DVD movies, you can click "Play" to make a preview.
Step 4: Start to burn AVI files to DVD
After everything is done, you can click "Next" to select your DVD burner from "Burn to" option. Then, you can hit "Start" to burn AVI files to DVD.
Tips:
Here below is the explanation of TV Standard:
"NTSC" is 30 fps, which is used in USA, Canada and Japan;
"PAL" is 25fps, which is used in Europe and Asia.
That's all, after the conversion is done, you can watch your torrent movies or digital camera videos on your DVD player.
on Feb 25, 2010 | Cameras
My dvd player says playback prohibited by area limitations
Sounds like it's the wrong region disc. Try a disc that worked before and if it does than there is nothing wrong with your dvd player it is the disc you are trying to play that has the issue.
May 07, 2010 | Sony DVP-SR200P DVD Player
I download free movies to hard drive, than I burn them, and my dvd player says no playback available or a big red x shows on tv screen, what am I doing wrong/
You probably have burnt the dvd disc using a video format that is not compatible with your player.
A lot of DVD players will not play .AVI or DIVx files that are commonly downloaded.
Your DVD player manual should list the formats it will play.
Convert downloaded movies to a compatible format before burning to disc.
There are several conversion programmes available via the web - at a cost of approx $50.00.
AVS4U works ok.
Oct 13, 2009 | Kenwood DV-6050 Multi-disc DVD Player
How can I burn a CD with a movie file to use on a DVD player?
First of all do you have the right kkind of dvd player?
I have a dvd player that plays DIVX movies, so I use Roxio software and burn a data cd of an avi. file. From my understanding AVI, DIVX, & MP4 can be read as a divx. Make sure you close you secission on the disc or it wont play.
Sep 19, 2009 | Panasonic DVD-S77 DVD PLAYER
HELP I made a movie using Windows (Vista) Movie Maker, was able to burn it to a CD-R and it appears to have burned to a DVD-R but it won't play on my DVD - message says: Playback feature not available
Well it looks like you saved it in the wrong format and belave me I done this as well save it as a MPG or AVI and not WMA or WMV your going to need another disc to burn but we all learn from little mistakes I pray it works for you if not you may need to use like NERO instead or ROXIO is good too good luck to you..
May 14, 2009 | RCA Scenium DVD Player DRX400N
Can I burn to disk a movie from my hard drive "avi file format"and play it in a dvd player
you cant play avi on normal dvd player,but you can convert avi to dvd format by use free softwere ( filmMachine )
Aug 10, 2008 | Panasonic Televison & Video
DVDS made on my computer
how old is your dvd rom  pal ?
if its too old syu more than 3 years  will hav the problrem in rotor mechanism
or else
try cleaning the lense
Jan 01, 2008 | Plextor PX-716UF CD and DVD Burners
JVC DRM10 DVD Recorder Logo
222 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
