Question about LG Computers & Internet
Cant install monitor drivers in L226WTQ monitor
My monitor shows in device manager only other devices and lg l226w(Digital) and when i try to installa drivers on internet or cd. Windows found driver software but encountered an error while attempting ot install it Access is denied. What can i do.? i'm using vista.
3 Suggested Answers
Bat1956
  • 585 Answers
SOURCE: HP w1907 monitor driver software will not load
"Access is denied" is the key here. It sounds like your login in windows does not allow you the privileges for that installation. Try logging in as an administrator and re-installing. One thing bothers me though, if this was purchased as a system, why would you need to install drivers? that should have been pre-installed.
Posted on Dec 14, 2008
kd0bga
  • 14 Answers
SOURCE: wf1907 lcd monitor driver
Ok so i was searching around the internet and found a similar problem with another monitor so for giggles i tried there method. This is the website where i found it : http://social.technet.microsoft.com/forums/en-US/itprovistahardware/thread/d7c0e5bd-2fcf-48ff-a79b-c157014fc821/#page:3
The Secoind wntry has a download. Download it then extract the files to the desktop. Dont worry if you get errors when the program runs it will fix them, if they come up just press enter to keep going. Once the program completes install the driver again and it should work as it did for me.
If you cant get to that website heres the post from it:
"Ok, once again i checked updates for HP My Display/Drivers, and found this:
http://www.portrait.com/dtune/hpw/enu/support_help.html
Here is a direct link to fix for "Access Denied" issue (HP LCD Monitors & Vista):
http://download.portrait.com/DRVFix.zip
Download DRVFix.zip. The fix contains 3 files including this readme. All must be in to the same folder.
  • readme.txt - This file
  • RestoreDisp.exe - Executable required to restore permissions. DO NOT RUN THIS FILE
  • DVRFIX.exe - Run this file in Administrator mode after reading the instructions completely
To perform the fix do the following:
  1. Extract all files in to a folder on your desktop
  2. Open the folder, right click on the DVRFIX.exe file and choose "Run As Administrator"
  3. Follow the on screen instructions. When complete, you should be able to install your drivers
If you find this helpful, please let me know.
I fixed this issue manually (from registry), about month ago.
Regards
Vesa"
There you Go, KD0BGA
Posted on Feb 19, 2009
  • 1684 Answers
SOURCE: Lg Flatron L226wTQ, power button failing
This problem is usually caused by a failure in the power supply board which in turn is caused by a failure of the filter capacitors. We have a repair guide article posted on our web site at: http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/ Check out the article and then open your monitor up and look for the failed capacitors, replace them if found and you should be back going again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on May 16, 2010
Monitor sleep problem
This type of problem is usually caused by a failure of the filter capacitors on the power supply board. The LG L204ws uses the AIP-0156 power supply which is the same board used in many of the LG monitors that were sold around the same time. Here is a link to a repair guide for the LG L226wtq model that used that board. The repair guide as pictures and videos showing how to open the unit and check the filter caps. There are parts lists showing what needs to be replaced too.
I hope this helps,
BuddyMc
Dec 01, 2012 | Computers & Internet
I have an LG Flatron L226WTQ-SF and my monitor has some "shadowing". If you need more infos I can send you some pictures.
If you are using analog VGA cable, replace it with one that has ferrite rings near both ends. The best is to use DVI digital cable but this depends on the capabilities of the videocard and the monitor ofcource, but I think this monitor has DVI input.
Aug 05, 2010 | LG L226WTQ-BF Monitor
I need window 7 driver for a lg flatron monitor L226WTQ-SF Cheers
There is no need to install any driver for the monitor as the inbuilt drivers always work with all operating systems and windows 7 have thousands of drivers inbuilt.
Mar 05, 2010 | Computers & Internet
Webcam on lg w2271tc doen't start. the drivers are from factory cd. i install them but the camera doent start. right after the installation machine needs restart. after restart , still the camera doent...
first install the driver software plug the usb to your pc...
then after that goto device manager click the (!) right click it goto properties and auto detect driver the pc will find the dll of you webcam then when he finds there were pop-up window you see if you see the highlight choose by your pc just click next it is only done. then you will not see again the (!). ok just follow my instruction
Mar 03, 2010 | LG W2271TC 22" 5ms LCD Monitor with Built...
I have a l226wtq-sf monitor, is there a 64bit windows vista /7 driver?
L226WTQ monitor won't turn on after 3 min.
Hi, I have this model and defective as a power problem, so I ordered capacitor package to solder, but the board was a little different model with the posted picture. As my poor knowledge, defective caps look fat so easily identifying its problem, but they were looked good. Anyway I soldered 3 of them matched with the procedure, but it kept on for 3 min then had gone and never turned on. After a while, it could turn on for an other 3 min.
Please help me~~~!
Feb 18, 2010 | LG L226WTQ-BF Monitor
How to install driver for lg lcd w1932. in cd came with monitor not have exe file and download from website too. in device manager monitor in status plug and play and not show name LG w1952 how to add...
well your monitor if connected with your graphics card wuld run on its drivers fine, the cd is just for the case if it does not gets detected. so u neednt worri bout the drivers and just njoy.
need ne help still, let me know
Nov 01, 2009 | Computers & Internet
How ti installa camera (web) without a cd ?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Oct 21, 2009 | Veo Stingray
LG Flatron W2252TQ 22'' monitor not working in digital mode
try to set your screen resolution to maximum using Display Settings in windows. Besides, are all software drivers for this monitor loaded and properly installed? Right click My Computer=>Properties. select hardware => device manager. Make sure video icons are not marked with question marks. if they are, install monitor drivers shipped with your monitor.
regards!
Jul 26, 2009 | LG W2252TQ Monitor
Webcam not working
this might bcos of webcam driver try installaing again your driver.........as you have not mentioend this webcam is with serial port/ usb port........if any of them go to my computer right click.......go to hardware......go to device manager........go to usb go to universal serial bus converter & check for driver details is working or faulty............hope this will help you.............Sameeraryan
Dec 27, 2008 | Dell Inspiron 1525 Laptop Jet Black
Need help installing
most people I have seen have to change the resolution in the display settings area of windows. after they do that the display will show properly without distortion
May 03, 2008 | HP Pavilion F1703 17" LCD Monitor
Computers & Internet Logo
122 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
