Question about Thermador Cooktops
Ignition does work - stove top doesn't light
All of the ignitors stopped working at the same time. The local gas and electric company had the power off in the neighborhood. I guess it surged when they restarted i. I replaced the burned circuit breaket at the box and their is power at the outlet when the ignition sysem for the cook top plugs in... but no spark.
How do I open up the cook top and what should I be looking to test and replace inside?
Thanks, Peter
  • petermartin3 Oct 30, 2008
    Hi Oconn329,
    The model number is SGCS365RW
    Serial no. 99090523
    This is the cook top I asked about yesterday... the igniters stopped working altogether probably due to a power surge.
    Thanks, Peter
Peter, does this cooktop have the star burners? If so, lift the burner caps off the burner and remove the center brass hex nut device hold down burner assembly. Once you remove all brass nuts. they will be about three inches long, then the main top should lift up. You can do this while unit is installed. Look for a blue, or black, or possibly a white plastic box about the size of a large box of matches. This is the spark modual. That should be your problem. Replace that. Carefully inspect all wires for burns also before you replace that modual.
Posted on Oct 31, 2008
  • 93 Answers
Please provide model number so that I can tell you what to do for this unit.
Posted on Oct 29, 2008
My GE Monogram gas range will not light. The igniter keeps going off but the gas will not light.
Hi, sometimes cooking spills stop the ignitor from working. Clean the cook top thoroughly and try it again. Spills can also make the ignitor go off randomly when you are not operating your cooker. Check if the ignition point where the zap comes from is not turned or bent too far from its original position. If you have a gas shut off make sure it is fully open to supply enough gas. If all else fails buy a cheap hand held ignitor to start your gas stove. If the cause is a spill which sometimes the problem can persist even after cleaning it may take a while for it to work again. If the problem is with all six burners then your ignitor probably needs replacing. When you hear the ignitor zap check to see if the electronic zap appears to jump across to the edge of the burner. If it doesn't it will not light the flame no matter how many times you try. I hope this helps you.
Aug 21, 2012 | General Electric GE Monogram 48""...
Gas stove tops: After 3-4 minutes of the gas being on for one or more burners, all of the ignitors keep on attempting to spark. They keep going even after the gas has been turned off and stop after 5 or...
Hi abbilou_78,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 30, 2011 | Whirlpool Cooktops
Ignitors clicking
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
May 10, 2010 | Thermador SGS36GS Gas Cooktop
Spark ignitors went on stove top
Jan 09, 2010 | Whirlpool SCS3014LS Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
The electric strike on my cook top wont stop striking even after the pilot lights or the gas is shut off. I have to unplug it to stop.
The problem is in the pilot ignitor Located under top, unplug the unit before replacing it. Write down all of the information ,mode, serial, and product number and name of stove. If you can get a part number, this would be very helpful. Take this to a local appliance parts house and they can help you.
Sincerely, shastalaker7
Oct 30, 2009 | Maytag 30 in. CSG7000 Gas Cooktop
I have a five burner stove top the ignitore just stopped working. What could be the problem
The ignnition switch will just stop working. Go to your local gas fitter and ask for a pietezzo switch, take yours along if you can, its easily accesable from underneath with a 10 or 12mm spanner.
Aug 02, 2009 | Dacor Preference SGM466 Gas Cooktop
Ignitors are not working
Nov 17, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Cooktops Logo
422 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
