Question about Fuji FinePix A203 Digital Camera
Help! automatic lens cover won't open on Fuji Camera
Hi, The lens cover on my Fuji Finepix will not open when camera is turned on. I have tried new batteries etc... but no good. If there is an obstruction there, can I correct it or will I have to send it for repair? Warranty is well out of date now. Thanks for any replies.
  • 12 Answers
SOURCE: fuji finepix a510
Check out this link:
After the basics, try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working. Dropping the camera loosens the debris and voila!
Posted on Jul 07, 2008
  • 256 Answers
SOURCE: fuji finepix z display date time
Start the MENU and navigate to the DATE option. Select thestyle of date and maybe the location. Be sure to save before exiting the menus. The date should display all the time now and in your chosen location.
Posted on Jun 11, 2009
  • 315 Answers
SOURCE: Fuji Finepix S1000fd Lens Cover - where can I
I have this company in the uk:
you could also have a look on ebay, just type in s1000fd lens cover and see what you come up with.
Posted on Jul 06, 2009
SOURCE: I am looking for a lens cap that will fit a Fuji Finepix S2000HD digital camera
I've just bought this camera off ebay and after purchasing noticed that it was going to come without a lens cap. After a bit of searching i found this link - it's not an official fugi one but it says it's for this camera.
I can't find one in the UK though
Posted on Sep 02, 2009
  • 3 Answers
SOURCE: Fuji FinePix S9000 battery change clears date/time.
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
Posted on Oct 13, 2009
  • 73 Answers
SOURCE: turn on camera..view finder and/or display screen
The s7000 has three different display modes: Screen, viewfinder, and off. Screen is for looking at the big screen, viewfinder is for looking through the digital viewfinder, and off should turn off all the displays. Try pressing the DISP button once. That should reactivate the screen and make it possible to use the camera again.
Posted on Jul 25, 2010
0 characters
1 Points
Fuji finepix a350 zoom error
This problem is quite common with this camera. Try pulling the lens out gently all the way till the lens cover opens. Then you twist it gently till you hear a click and it should be fixed. Let me know how it goes.
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
Fuji finepix e510 won't turn on
If your Fuji e510 battery system is like the Finepix S3000 or the S3100 take a look at the following postings: Finepix S3100 (Camera power does not come on...) by banobo of Feb 07,2008 and check out solutions #2 & #4, (Mine is #4), Also see posting by "tomawamba for Fuji S3000" and my slightly differently worded solution.(Only one posted). May be best to get camera working before connecting with anything else. Good luck, be patient.
Jan 18, 2009 | Fuji FinePix E510 Digital Camera
Mine did this too, and the lens cover only opened half way. I used a cotton wool bud to push the lens cover back and held it back until the lens clicked into place, turned it off and on and then it was fine
Jan 13, 2009 | Fuji FinePix 2650 Digital Camera
Fuji a345
Simply wear and tear.- dirt ingression- damage from a knock- nothing you can do about unless you are a watchmaker. A repair will be as costly as simply replacing it Check out Fuji support though to be sure.
Aug 15, 2007 | Fuji FinePix A345 Digital Camera
Camera lens cover wont open
Get onto Sony Tech Support team. This is a camera failure the will honour the warranty here I am sure.
Jul 06, 2007 | Fuji FinePix 6800 Zoom Digital Camera
Zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Fuji FinePix A203 Digital Camera Logo
43 people viewed this question
Top Fuji Digital Cameras Experts
Richard Roberts
Are you a Fuji Digital Camera Expert? Answer questions, earn points and help others
