Question about Presto HeatDish Compact Heater
Presto heaters my presto heat dish plusRise heater make a noise every time turn on, .Turn on and of every 10 seconds?
  • 1 more comment
  • elisacouture Dec 03, 2008
    Since my daughter put a damp sweater on it in an attempt to dry it, the buzzer is on all the time. Help!
  • jkelliott Jan 15, 2009
    It buzzes when it is right around medium....why?
  • tulip09 Jan 17, 2009
    i just purchase a unit. My question is does it automatically turn off when it gets too hot?
We have one in our office where our entry is pretty close to teh main door. It used to buzz all the time after being on for maybe 10 minutes. One day I got sick of it and took a cloth and some windex and cleaned the reflecting dish, and that actually stopped it
Posted on Nov 05, 2008
Heater will not turn on
The switch could be defective.
Nov 18, 2016 | Presto Heating & Cooling
Where can i locate the on/off machinism for the presto heat dish?
Handy top-mounted thermostatic control maintains the desired temperature automatically plus it has a special safeguard features turn the heater off automatically in case of accidental tip-over. Because of this technology they eliminated an on/off switch. You have to unplug it if you want it to be totally off. sorry
Mar 19, 2010 | Presto HeatDish® Plus Footlight® Electric...
RE: Presto Heat Dish buzzer going off
I almost threw my heater out! I cleaned this morning with Window Cleaner and it works just fine now. It was just dust. I cleaned the round metal area not the coils.
Hope this helps.
Emailed Presto about replacing the buzzer and here is the answer I got:
There is no such part. Buzzer sounds when heater:
- is tipped
- rests uneven on floor
- is too close to furniture or wall
- has too much dust on parabolic dish
The most common reason is that the parabolic dish is dusty.
To clean the heater:
1. Unplug the heater and clean it when it is cool
2. Spray a cloth with an all-purpose cleaner such as 409
3. Wrap the cloth around a long handle such as a wooden spoon
4. Wipe between the grate from the outer edge to the center
If you have further questions, please let me know. Or call us at 1-800-877-0441 Monday through Friday 8:00 a.m. to 4:30 p.m. Central Time.
Jan 11, 2010 | Presto HeatDish Compact Heater
My heater makes this constipating noise and the "tilt" alarm goes off after 10 minutes. I'm never able to turn it to the high position.
This is the answer I got from Presto. I cleaned it with window cleaner, wooden spoon and paper towels. Dish works great now.
- is tipped
Dec 12, 2009 | Presto HeatDish Compact Heater
Presto Heat Dish "buzzing" while on and sitting stationary
This question has been answered. I was having the same issue and I can tell you that the solution gregstobbe gave worked for my heater.
http://www.fixya.com/support/t1225707-presto_heat_dish_buzzer
Oct 14, 2009 | Presto HeatDish Compact Heater
Odor coming from the Presto HeatDish
Hard to tell without more information. Bets to call Presto customer service at 800.877.0441. Have the model and series number found on the back of the base.
Mar 23, 2009 | Presto HeatDish Compact Heater
Bypassing the buzzing mechanism
I have no solution. I attempted to repair the noise problem using a post that described how we should by-pass the buzzer. NO GOOD! I am trying to live with this piece of noisy ___p!!!! let me know if you find a correct solution. thanks, jim
Nov 10, 2008 | Presto HeatDish Compact Heater
Presto Heat Dish w/footlight
This heater must be flat on the floor or it will buzz, and the metal dish must be clean or it will transfer heat to the safety device. If this does not solve the problem call customer service at 800-877-0441.
Jun 14, 2008 | Presto Heat Dish/Electric Heater with...
Presto Heat Dish Blows Circuit
It sounds like the heater is drawing more amps than your fuse is capable of handling. look at the i.d. plate and see what the wattage is for the appliance.
Nov 08, 2007 | Presto HeatDish Compact Heater
Presto HeatDish Problem
I rewired my heat dish. I UNPLUGGED THE HEAT DISH. I loosened the three screws on the back and removed them. Then I unclipped the dish at the bottom. The dish should be loose and the bottom section of the dish should be detached from the plastic casing. Look inside the casing at the bottom. There is a red cable attached to the buzzer (it’s the silver metallic piece). Detach the red cable from the buzzer. Now look directly behind the buzzer is a black wire that connects to the circuit next the buzzer. Attach the red cable to the female receptor foot the black cable. Plug it in and it should work fine. This will permantly disable the buzzer, SO YOUR HEATDISSH NOW LOINGER HAS A WARNING SYSYTEM. IF YOU TURN YOUR HEATER OVER THE BUZZER DOES NOT GO OFF, THE BUZZER ALSO INDICATES OVERHEATING OF THE UNIT. SO BE CAREFULL. MAKE SURE THE UNIT IS UNPLUGGED WHEN WORKING ON IT. GOOD LUCK AND BE SAFE
Oct 19, 2007 | Presto HeatDish Compact Heater
Presto HeatDish Compact Heater Logo
376 people viewed this question
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
