I changed my computer. I lost my Brother disk.How can i get my printr Fax copy to be compatable with computer. it is MFC210 Serial # MSF276850 . reference 8CAB1120101
  • 4 Answers
Go to Brother.com and download the driver pack for your printer.
http://www.brother-usa.com/Downloads/Default.aspx
Posted on Oct 29, 2008
Ned user manual for brother mfc 210
Hi
To copy a page in Brother MFC210 you need to press copy button on your printer, load your document and press black copy (to copy in BW) or color copy. You can also select number of copies by pressing keys 1 to 99 before pressing black copy or color copy button.
For your user manual you can visit this link---
Brother MFC 210 User Manual
Daniel Scott
Jun 12, 2010 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
I have lost the manual for the brother 515 fax can I get a copy anywhere
Click on the following link and enter your machine number. The user guide is the owner's manual.
http://brother.com.au/customersupport/userguides.asp
Apr 19, 2009 | Office Equipment & Supplies
Cannot copy photos from my SD card
If the printer is connected to your PC with the USB cable then as soon as you insert the SD card in the slot it acts as a drive. Open up "My Computer" and search for the new drive (e.g. E: or I:). You can explore the SD card as you would with your hard drive and you can copy the photos on the SD card to your computer as you would normally copy files.
Apr 05, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother Intelli755 fax lost manuel. . .when I push copy, nothins
HELLO JUDIE! YOU CAN DOWN LOAD A MANUAL & BROTHER .COM. AS FOR THE LINE IT SEEMS TO BE COMIMNG FROM THE FILM CARTRIDGE , THAT IS ALSO THE PRINT CARTRIDGE ON THAT MACHINE. ARE YOU USING REFILLS? OR BROTHERS OWN , CHECL THE CART. GOOD LUCK BROTHER SR TECH
Jan 31, 2009 | Brother FAX-575 Plain Paper Thermal
INSTALLING DISC FOR MFC210
Hi Ellen, not sure if your problem is that you can't download ar that you don't know where to find the software.
The Full Driver & Software Package can be downloaded from the Brother website (63Mb).
hope this helps
Albert
Nov 09, 2008 | Brother MFC-210 All-In-1 Print/...
Installation brother mfc 420 cn
You can try searching the web for the driver for that machine or call Brother directly at 1-800-284-4357 and order another cd
John
Dec 09, 2007 | Brother MFC 420CN All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
