Question about Maytag Dishwashers
D/w maytag quiet series 300 does not work.the rinse light flashes and 9 shows up .
  • fixitrs Oct 29, 2008
    I need the Maytag diagnostic error codes for this dishwasher. MDB6601
    Scholar:
  • 155 Answers
Check out
Posted on Oct 29, 2008
  • fixexpert Oct 29, 2008
    Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
    If you take off your lower access panel below the door, you should see the diagnostics service sheet on it.
    the error code" 9" implies the problem in the door or doorswitch.
    just check whether the door of the dishwasher is tightly and properly closed as there is a sensor which detects open when the door is not closed properly.
    thanks.
  • 13,433 Answers
Here is a possible solution
The problem seems to be a poor connection between the ribbon cable from the keypad and the processor board. This fix was fairly simple--Turn off the power, remove the back of the door, unscrew and remove the lid on the processor box, push to open the lock on the connector and remove the ribbon cable, clean the end of the cable by light rubbing with a non-abrasive pencil eraser, put the cable back in the connector and lock. Reassemble. Full operation was restored.
Remember to unplug or switch the power off before working inside appliance.
Also consider if your washer is covered by warranty it may be best to get those free warranty repairs.
    Genius:
  • 1,550 Answers
Are you getting any error code .
Please provide some more information to your problem .
  • SAM ANDERSON Oct 29, 2008
    Did you try reset ?
    Unplug the power supply for 30 minutes and plug back the power supply to the unit .
    If the initial help did not work
    The the problem is caused by a stuck key on the touch panel console.
    If the control board detects that a key is stuck in the “mashed-in”
    position, then the dishwasher will suspend operation and
    flash the light for that key until the condition is fixed.
Maytag dishwasher will not start
REPLACE THE DOOR SWITCH.....NOT GETTING RUN COMMAND CAUSE SWITCH N DOOR NOT BEING MADE
Oct 15, 2013 | Dishwashers
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series 300 owners manual
my dishwasher does not want to work anymore it has a big L flashing
Jun 14, 2009 | Dishwashers
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Maytag quiet series 300
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
MAYTAG QUIET SERIES 300 DISHWASHER MODEL MDB7600AWW
Order and replace the front panel only - not the control card. This will resolve the problem.
May 07, 2008 | Dishwashers
Dishwashers Logo
378 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
