Question about Goldstar DH504EL Dehumidifier
Another question I cleaned the whole thing and it still does not work. The fan and compressor do run like normal, just no water is ever collected. Any other ideas one what could be wrong? We have had the dehumdifier for a year or so and it worked fine up until a month or so ago. It runs like normal, but no water is ever collected. We recently bought another dehumidifier that is the same size as this one and it fills at least once a day so I know their is enough humidity for the other so it should work. It is not iced up or anything either. Any ideas as to what might be wrong? Best Solutionposted on Sep 04, 2006By catriver Rank: Guru Rating: 86.88%, 160 votes halver, you want to make sure that the compressor and fans are operating. Warm moist air is drawn over the cold evaporator coils where it condenses and drains. Dry clean air is drawn over the condensing coils, heated several degrees and returned to the room. If your evaporator or condensor coils are dirty, this could be one reason. Of course if the compressor is not running would be another reason. Check the air filter too. Catriver...post back
  • Anonymous Apr 21, 2008
    the first year it worked great. It no longer collects water.
  • nickname2 Apr 29, 2008
    Tried cleaning it, still does not collect water. One year old. Waste of money.
I have the same problem. I believe it is because it has a refrigerent leak. When there is little refrigerent, the begining of the coil will freeze up. I would really suggest calling the manufacturer. It is defintely something to do with this specific model
Posted on Jul 10, 2007
Runs but no longer collects water
In the price range, most of the comparable united are the same under the skin. I like whirlpool since replacement parts are widely available.
before you condemn the unit, check three airflow and the temperatures of the suction and discharge tubes a few inches from the compressor. If the discharge is hot and the suction is cold, the circuit is probably still whole.
Nov 30, 2014 | DeLonghi DE400P Dehumidifier
Does not dehumidirfy
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Oct 11, 2010 | Maytag M7DH65B2A Dehumidifier
Not removing water and says tank it full
I just had one giving me the somewhat the same problem. Upon taking it apart I found that the entire inside was filthy. This thing runs in a work area in my basement and sucks up all of the dirty air. When you take the water out of the dirty air you have nothing but the dirt and the water. When you mix those together you get mud which is what clogged everything up in mine.
Dehumidifiers need to be clean on the inside to run properly especially all of the fins on the condensor. You will probably have to take it apart and clean it. Concentrate on the fins and the water collection areas. Dehumidifiers remove heat from the air which causes the humidity to collect on the condensor. As it collects it turns into water droplets. Gravity pulls the water droplets into the water collection areas and that flows to your tank. There is some sort of float in your tank that lets the dehumidifier know it is full and shuts it off with some sort of switch. It does this so it does not just keep running and eventually pour water onto your floor. It sounds like your switch and/or float is stuck. Find the float and switch and manually work them to make certain they are working freely, clean if necessary.
If the dehumidifier does not remove water like it should it is probably not getting good airflow. There are ice sensors on the evaporator that tells the compressor to stop working. However the fan will still run to pull warm air across the ice so that it melts, goes into the water collection area and into your tank. Some of these ice sensors work by measuring air flow. If there is no air flow or very limited air flow the sensor will tell the compressor not to work. The fan will run again to melt the ice so that it melts and is removed. If your condensor is dirty and does not allow the air to flow, this could cause your problem.
Mar 24, 2010 | Danby DDR6588EE Dehumidifier
Unit runs but no water collects in bucket. Unit is over a year old and has run continuously that whole time. Up till now it has performed beautifully. Is it just worn out?
Hi;
Your dehumidifier is similar to a refridgerator or air conditioner. It has a compressor and coils, and a fan. Basically, the unit has to **** in air with it's fan, and as the humid air goes across the cold coils, the humidity condenses in to water. If the coils are not getting cold, they won't condense any water, or if the fan isn't running, or the coils are dirty. If you check your unit over, see if you can tell if anything isn't working. Make sure the control knob is set at the highest setting. If the compressor lost it;s refridgerant charge, and won't get cold, it isn't probably worth fixing
Nov 23, 2009 | Whirlpool 75-Pint Dehumidifier
Runs but does not collect water.
compressor run but gas charge not enought
so it not very cool,and no water come out
Aug 23, 2009 | LG LHD45EL Dehumidifier
Fan runs, but compressor does not start
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 05, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Jun 08, 2009 | Whirlpool Dehumidifiers
Oil inside the water collection res
the compressor runs in oil. suspect you have a quite bad leak and loss all the gas - hence no water collection and the compressor oil is being pumped out thro the leak
Jun 26, 2008 | Whirlpool AD25BBK Dehumidifier
Everything works, but does not collect water
I have the same dehumidifer - make and model. I bought it less than a year ago. It too runs fine, but now collects no water. Did you ever discover how to fix the problem?
Sep 04, 2006 | Goldstar DH504EL Dehumidifier
Goldstar DH504EL Dehumidifier Logo
245 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
