Question about Motorola Talkabout T5720 (7 Channels) 2-Way Radio
Motorola TalkAbout Radio T74000 REPAIR
I have a pair of Motorola Talkabouts T7400 one of the radios used very little --- One of the radios was left outside on a deck overnight and now even w/new battery replacement it will not work. Is this worth fixing --- as I indicated it has only been used once or twice. Thank you. M. Knight
  • Motorola Master
  • 1,654 Answers
It depends on how long ago the water damage happened, on whether it will be repairable or not. If it was fairly recent, and you feel you got it pretty well dried out, then it is possibly repairable. If it has been more than 10 days or you left it wet, it is probably ruined from corrosion growth. If caught early corrosion can be kept to a minimum.
Get your radio to the service center of you choice right away to find out if it is repairable. If you do not have a repair center you can look us up on the web by our username.
Posted on Oct 29, 2008
  • eradiostore
    eradiostore Oct 30, 2008
    I failed to prefice my solution by saying it sounds like the radio has gotten moist or wet while outside overnight.
Where can i find a replacement user's guide for the T7400
You could download the manual from :-
http://www.motorola.com/mdirect/manuals/T7400_UserGuide.pdf
You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 03, 2010 | Motorola Talkabout T7400 (22 Channels)...
Hi, i bought a Motorola CP200 radio and realised that it didnt work with my Motorola Talk-abouts! now i know that there is a programming that i need to operate with!!! so my question is....how can i know...
Take it too radio-shack and ask the salesman to try out a frequency meter to get the freq. you can get programming help by contacting motorola direct...1-800-638-5119
Aug 23, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
One radio not recieving
You need to check your interference eliminator code. It sounds like they are not set to the same code. Also, if your radio has a Qt filter, set it to zero.
Here's a link to the manual http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5300_T5400_User_Manual_E.pdf
Aug 11, 2009 | Motorola Talkabout T5400 (14 Channels)...
SX700 and T5522 talkabouts
Hello Walvis,
Based on a quick web search the Motorola SX700 appears to be a Family Radio Service unit for use in the USA and the Motorola T5522 appears to be PMR446 radio for use in the UK. While the radios are similiar, they don't operate on the same frequencies so they won't be able to communicate with eachother. Because both FRS and PMR446 are very similiar, Motorola often markets versions of the same radio (with slightly different model numbers) for each service.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Motorola Talkabout SX700 2-Way Radio
Communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Neither radio will receive or send
The radio probably needs reprogrammed to match the other units. Check your owners manual for instructions.
Oct 18, 2007 | Motorola Talkabout FR50 (14 Channels)...
Motorola Talkabout T5720 (7 Channels) 2-Way Radio Logo
153 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
