Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hi! Please help! Our Saeco Primea coffee machin is stuck on the "boiler filling" mode and we cannot get it to make any type of coffee, cappucino, etc. The display has 2 lines: line 1--flashes between "push OK" and "to start," and line 2--"boiler filling" (which stays on constant).
--When OK or the center "cup" symbol is pushed, "in progress" is displayed and the machine attempt to work and make noise.
--Then a little later, "cycle interrupted" appears.
--Then the message goes back to the original message of flashing between "push OK" and "to start," and "boiler filling."
--All this time, the cup warming plate gets very hot.
--I've tried unpluging the Saeco overnight, resetting to the original factory setting, and checked all water levels, and dump all used water and ground coffee.
--I was able to go to the "Menu" in this "boiler filling" mode and ran a "milk rinsing cycle" and had hot water running through the "double coffee" nozzles (not single "hot water" for tea nozzle on the left) without problems.
Please tell me how to get out of this "boiler filling" mode. Thank you so much! Tom.
  • scotom2020 Oct 31, 2008
    Edje1970,
    Thank you for your reply. It sounds like you know what you're talking about since you had the same problem. I will print out your write up regarding to how your Primea was fixed, and include it with my Primea when sending it to Saeco for repair. This will definitely help them expedite fixing it.
    Thanks again for your good advice!
    Tom
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Posted on Oct 30, 2008
My machine had the exact same problem, but when I brought it to the service center, the guy told me it was not the switch. He said it just had to be cleaned, which he did in about 15 mins and then it worked fine. He said to try not to use oily beans, because if they are too oily, it will clog the machine, and that's why he had to clean it. Hope this helps.
Posted on Dec 02, 2009
I have a Saeco Primea Cappuccino Touch Plus. how do I adjust the machine to make the coffee fill up a cup or mug(using different size). Can the machine work out the size of cup used automatically.
Yes, you can adjust the sizes and aroma according to your taste,just hold the the product without releasing your finger,the screen will show programming.Then follow the instructions on the screen. Easy.
Apr 26, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Push ok to start boiler
Try opening the steam valve before pressing ok.
This will let water into the boiler before the heat element comes on.
Apr 23, 2009 | Saeco Incanto Classic Espresso Machine
Primea ring hot milk
if you go in the menu there a temperature setting for that machine pierre
Jan 11, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Water filter initiation failed
Did you this steps?
Fill the tank with fresh water.
Let the filter soak for 30 minutes.
After 30 minutes discard the water in the tank and refill with fresh water.
Place a container under the spout.
Press the cup button in the middle.(Filter on, yes)
Press the cup button again.(press ok, initialisation)
The machine initialises the filter.
Press the cup button again.(done initialisation)
Then press MENU repeatly. When the "exit" message is displayed, press the cup button. In this way, the machine ends the start-up phase.
Best regards
/Mirran
Sep 24, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco primea Ring
What i know there will not be any dvd or cd, it´s only on paper:-(
/Mirran
Sep 03, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino brewing very slowly
Try to descale the machine.
Try to adjust the grinder little.
/Mirran
Aug 21, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker fill water tank
The Primea do not have a float, it have a magnet and inside the machine there are a printed circuit card, this send a signal to the powerboard.
Jun 20, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
Nov 10, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
1,252 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
