Question about Dell Inspiron 8200 Notebook
Touch pad is not working
The touch pad seems to have a mind of its own. It makes the screen curser drift rapidly to the bottom or top corner and stays there. You can try to get it to respond, but it goes back to the corner. It also affects using the mouse. It will drive the curser back to the corner if you do not continue to move it back with the mouse.
  • 4 more comments
  • Anonymous Nov 26, 2007
    Touth pad does not work the cursor flyes down left corner or up right corner. Is it a driver problem or is somthing set out of function?
  • rock79in Dec 07, 2007
    Downloaded new driver from Dell's website, Still the same problem. Earlier it used to go to corner by itself. Now touchpad isn't working at all..
  • Anonymous Apr 21, 2008
    touch pad drifting
  • Anonymous Apr 23, 2008
    touch pad doesn't work at all, neither do the left or right click buttons. Mouse plugged into the USB port does work.
  • Deanna818 Jun 19, 2008
    My touch pad is not working, if I want to click on something it takes a few hard clicks and sometimes that doesn't work either. The right and left click buttons work but the touch pad doesn't. Is there away for me to fix this issue.
  • Anonymous Dec 05, 2008
    I tap on the touch pad and it does not work
It's a software issue with the driver, and Vista. I had this problem on my Acer notebook, and I fixed it by doing the following:
1) Goto "Control Panel -> System"
2) Click on "Device Manager"
3) Goto "Mice and other pointing devices"
4) Uninstall what you see there and select "Delete driver file for this device"
5) Click OK and restart your computer
6) After reboot, it'll have installed Microsoft's default ps/2 mouse driver (which works fine except for the scroll).
7) Goto "Start -> Control Panel -> Mouse"
8) An error will pop up saying something about Synaptics driver not found. Just click "Yes"/"OK" to kill it off for good, and restart again if needed.
9) After reboot, your problems should be solved.
Optional:
If you want scrolling and other functionality back with your Synaptics touch pad, download and install the Synaptics Touchpad Driver 9.1.11.0 here:
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Synaptics-Touchpad-Driver-91110.shtml
If it screws up again with this driver, just kill it with the steps above, and just use the default Microsoft driver until Windows 7 comes out, or switch to Linux (which ever you decide to do first).
Posted on Sep 23, 2009
I had a similar problem which I remedied by removing and cleaning the touchpad, there was some dirt which had collected around the edges of the pad underneath the case. The only drawback is that the majority of the laptop must be disassembled to get to the touchpad.
Posted on Jul 27, 2007
Some times the touch pad is working and some time not working when drag one side then the arrow goes to other side. and one thing more DVD/CD RW not dectected, because CD shows in my computer and the icon is also present on the task bar near the Clock, One day i disconnect the USB flash drive but mistakly i disconnect the CD,So now the CD not appeared.
Thanks.
Posted on Oct 09, 2008
I think the problem is actually the pointer stick. I disabled the pointer stick and it fixed the problem, the touch pad is still active and works perfect. Latest alps driver from Dell is required for this fix.
Posted on Apr 07, 2008
Just twist the whole laptop a bit (bend it back and forth in the 2 opposite corners). like someonen mentioned; there is some pressure on the touchpad which makes the mouse go to the end of the screen. you can also disable the mtouchpad in the bios before startup (press F2). the cursor moves to a default when pressure is applied, it automatically resets after a few seconds (IF the pressure is gone)
Posted on Oct 04, 2007
  • 624 Answers
I had the same problem with a touch pad several months ago. My fix was to download the latest Dell driver.
Posted on Nov 26, 2006
The curser wanders off sometimes to the top others to the bottom, i changed the bios setting to only use touch pad but you can still use the stick in the middle even tho i clicked only touch pad, the...
If its an external mouse that uses laser for pointer location rather than the internal ball, then you might need to purchase another one. they tend to do that. Mine still does it every once in a while, but goes away when i pick it up and set it back down. good luck
Sep 04, 2009 | Compaq Evo N610C Notebook
Mbj58 wheel mouse curser wants to go all over screen
Hi a. Have you tried another mouse and
b. Are you using a glossy or prismatic mouse mat? Try using a different one or a sheet of A4 and see if this fixes it
hope this helps Mark
Aug 22, 2009 | Logitech Wheel Mouse Optical
Curser runs off screen and won't come back.
this could be cause by a bad touch-pad sensor. if it crawls off-screen without touching the mouse.
Jun 19, 2009 | Dell Latitude D610 Laptop Computer -...
Curser moves my page left to right
This sounds like the functionality of the mouse pad, in the better mouse pad drivers, there is an area designated for scrolling, usually up and down is on the right edge of the pad, and left and right is on the top. You should be able to turn this off in your mouse drivers, with these drivers almost always comes a little icon on the bottom right corner of the screen, double clicking this or right clicking should bring you some options.
Mar 12, 2009 | Gateway T-1625 Notebook
HTC Touch Screen malfunction
hi, i want to formate my htc touch phone.... i dnt want a number formate.... i want a clear full formate
Jan 31, 2009 | HTC Touch P3450 Smartphone
Acer aspire touchpad over sensitive
Your laptop should have software pre-installed for your touchpad. This should probably be in the Control Panel. Once you find the software there should be options to change the sensitivity. Hope I helped.
iSpearz.
Jan 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Touch pad curser has mind of it's own
go to the control panel and select mouse, then change the settings there
Nov 26, 2008 | Acer Aspire 3000 Notebook
Drifting cursor
optical mouse (laser) will note work on shining surface (glass)...
PLEASE RATE ME ( FIXYA )............................
May 26, 2008 | Toshiba Tecra M2 Notebook
Drfting cursor
This is a well known occurance with laptops and is not something you can fix. Occasionally the manufacturer will release a patch to try and help, but this is very rare.
May 22, 2008 | Toshiba Tecra M2 Notebook
Screen minimizes when using the touch pad
If you touch the top right corner of the touchpad, it restores down the window you are currently in. The bottom right corner of the touchpad minimizes the window you are currently in. The bottom left corner of the touch pad brings up the start menu.
Nov 05, 2007 | Toshiba Satellite A135-S4427 Notebook
Dell Inspiron 8200 Notebook Logo
4,250 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
