Question about Acer TravelMate 292ELMI Notebook
I need a graphic card
Hi there to all the readers! My problem is that I need a more powerful graphic card and I've searched the Internet but I didn't find anywhere what type of graphic card fits into my Notebook. Thank you very much for your answer!
    President:
  • 2,961 Answers
Unfortunately you wont be able to upgrade to a graphics card, as only high end gaming laptops come with a seperate graphics card, most other laptops have only on board graphics,it may help if you install more memory then allow more graphics memory to be used, normally laptops only use 16mb - 32mb of graphic memory, which can be increased, although your on board graphics may not be good enough for modern gaming
Posted on Oct 10, 2006
SOURCE:
How do I unplug power cord from ASUS nvidia GeForce 8500 GT?
there is a small clip that needs depressed on it .
Dec 08, 2017 | Computers & Internet
Red squares
If the system works properly in "Safe Mode" the problem is with your drivers. Try and update the drivers by downloading them from the manufacturers website. Although, having looked at the spec, it could just be that you are not using the supplied monitor adaptors to run your display. Try it that way and see. Good luck.
May 11, 2012 | Nvidia GeForce GT 520 1 GB DDR3 Video Card...
My 9800gt 512mb 256bit after 10 mins it shutdown.can u help me
Often times, people will upgrade their graphics card without updating their power supply. Check on the box for your graphics card and see what amount of wattage the card needs. When I bought my first card, I didn't check and the computer shut itself off because of overheating. So you may need to buy a power supply that can handle the power hungry graphics card. Hope this helps!
Jul 29, 2011 | Computers & Internet
Im looking to upgrade my dc5000 sff graphic card and I wanted to know what kind of video card i need etc; pci, pci-express..... And if you have a product that could be used in this computer that would be...
Hi W Matt - Unfortunately your PC has only PCI slots available, no dedicated video slots like AGP or PCI-e.
You can get a PCI card with better/faster graphics than you have but the difference won't be dramatic.
If you want something to run Windows 7 in full graphics (Aero) mode and some games at medium settings I would recommend a card using the Nvidia 8400gs chipset. It's a fairly inexpensive card made by many manufacturers and won't put a strain on your systems small power supply.
You must remember that you need a PCI card that is also a low profile version.
I've created a search for what you need at Newegg (an online seller) and you can view the kind of card you need HERE.
Happy Computing!
Mikeywaf
May 19, 2011 | HP Compaq dc5000 Small Form Factor PC...
I've had kodak easy share on my computer for years. Recently I tried to access the pictures and got "can not process your request..(error code 9477068x301x94770168x) I have called them &...
Forget easy share, just take out the memory card (SD card) from your camera and buy a SD card reader. Put this memory card in the card reader and plug the card reader in your computer USB. It will work like a normal pen drive and you will find all your pictures inside DCIM folder of your memory card. Copy all pictures in your computer HDD to be on safe side.
May 07, 2011 | Computers & Internet
Hey! I´ve bought Sapphire RADEON HD6870
you should check that your motherboard is compatible with this video card or not (search in google or ask support center of the company).
if it is compatible do these steps:
intercept all of cables of your PC case and even power cable of your monitor.
evolve battery of bios then wait for 25 minutes then connect all of cables and try turning on your PC:
1- with battery of bios
2- without battery of bios
it should work.
(this works cause the motherboard reset it's bios and start correctly again).
if it doesn't work, surely your video card is damaged. it is not about how you mounted the card or it is not damaged physically by you. this card is damaged while producing in the company.
in fact in every 100 products of a company it is possible that 2 out of them be damaged.
so take your video cad to a guarantee center. they will test it and if it work wrong or doesn't work,they will give you a new video card.
Jan 09, 2011 | Sapphire RADEON HD6870, (1 GB) DDR5...
No input signal go to power save
This is a knowen problem for this model see the following link to see if you qualify for a limited warranty that expires December 31, 2009.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c01514044&product=3376325&printable=no&encodeUrl=true
Feb 15, 2009 | HP Pavilion s3020n (882780985063) PC...
Acer TravelMate 292ELMI Notebook Logo
197 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
