Question about Acer Computers & Internet
The screen is broken and i need to connect it to a pc monitor in order to get data off but the monitor is saying no signal.... it showed the windows startup but then turns off
    Problem Solver:
  • 10 Answers
Most likely, that's because the video resolution or frequency is not set correctly for the "new" monitor.
i am assuming that you are NOT ref'ing to a laptop computer being the one you need data from...
your best bet will be to begin tapping the "F8" key prior to seeing the windows load screen. you should see the "ACER" screen first then it will normally transition to the windows loading screen. when you see the ACER screen, start tapping the "F8" key approximately once per second (if you tap too rapidly, you will get a keyboard error... in which case, just reboot the computer.). once the "F8" stroke is successful, you should get a list of options. one of the options should say "Safe Mode" and "Safe Mode with Networking". using your arrow keys, select one of them and press enter. hopefully, being in safe mode will allow your "new" monitor to display the default frequency and resolution.
Posted on Oct 29, 2008
No signal monitor F-417
screen has been identified and installed but you need to send laptop signal to this second screen
there will be a key on the keboard or you can right click the desktop then proceed to send signal to the attached second display
Nov 26, 2013 | Neovo Computers & Internet
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
Nov 11, 2013 | Westinghouse L1975NW Monitor
Monitor showing no signal and button not working
The monitor needs a signal ( source), i.e., DVD, TV, to show a picture. If your monitor shows no signal then either the source is not connected or not functioning. Check the connections from the monitor to the source. Also, check that the source is functioning properly and is receiving power.
May 24, 2011 | Sony XVM-H65 6.5 in. Car Monitor
Viewsonic vx2835wm monitor, in DVI mode connection, altough getting signal from the PC(Other monitor connected and tested for graphic card problem-No graphics card problem!!) , Prompts "No input-signal"...
You will need to change the resolution of the screen on the computer to 800-600 and the bit to 24bits or 16bits, to do this right click on the windows screen, and click properties, goto settings.
You should see a slider at the bottem left of the screen to adjust the resolution, and a drop down bar on the other side for the bit rate. This should solve the problem, also you could open the scond screen also in the display properties, and drag what you need to see on the screen to that screen, you will know what i mean when you open screen 2 it just expands the desktop. hope this helps.
Aug 21, 2010 | ViewSonic VX2835wm Monitor
Broken screen of Asus 1000h
yyou could remove the hd and hook it up to another pc then transfer your files
Jan 25, 2010 | ASUS Eee PC 1000H Laptop
Screen broken
When your screen is broken in most cases, the system can't boot because the screen reads as damaged or not attached to board...why are u doing a windows installation? Is there more to this, please give me exactly what's going on so i can help you
Screen comes on says Acer then No Signal, and goes out. if shut power off and then back on get same result.
This means the monitor believes it's not connected to the computer. Verify the cables first of all. Then try booting in safe mode (F8 key at PC startup) in order to verify that the PC is sending data to the proper video port (you might have a dual VGA / Digital output, for example, and the monitor might be connected to the wrong PC port). Quite often, a "bad signal" will be the same of "no signal"; and you can have a bad signal if the monitor resolution on the PC is set too high. This could happen if you installed a high-resolution capable monitor, and then replaced it with a not-completely-plug-and-play, lower resolution one. The PC would keep sending hi-res signals to a monitor which can neither interpret them, nor tell the PC "please slow down". To check this last possibility, reboot your computer while the monitor is ON. When PCs reboot, they usually drop back to standard VGA signaling, which all monitors understand. If the monitor abruptly comes to life and displays a boot screen, then goes No Signal again after several seconds, you've got a resolution issue; get in Safe Mode with F8 key at boot, and modify the screen properties (right-mouse button on the desktop, then Properties).
If everything else fails, try also connecting the monitor to another PC or laptop, to see if it works there.
Dec 04, 2009 | Acer AL2223W 22" LCD Monitor
LG CB553H monitor has power and menu that sais no data. When I connect to a pc there is no display.
A monitor display showing "No Data" indicates that either the PC is not sending any usable video signal or the monitor is not capable of displaying the incoming video signal. To determine which is at fault, you would need either a known good second monitor or a known good second PC.
Additionally, it is also possible that neither is at fault and that you simply need to lower down the Screen Resolution and/or the Screen Refresh Rate of the computer's display properties to match the limitation/capability of the monitor. A method of verifying if this is the case is to start the PC in "Safe Mode" by pressing F8 after POST before Windows boot.
Alternately, there are some instances that it is the video cable that is the issue. To verify, you can try wiggling the cable to the connector end that goes to the PC's Video output.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 02, 2008 | Compaq FS 7550 17" CRT Monitor
I am trying to connect my laptop to the Polaroid LCD TV, as i would like to use the TV monitor as a computer monitor (my laptop monitor is broken). So I connect the correct wire to correct places, however...
The simple patch that I found (same problem) was to start by using any old monitor that I could borrow to set up my Dell Laptop.
After getting the Laptop booted on a regular monitor I right clicked on the desktop and went to properties then to the settings tab.
Here I found the dual monitor settings (#2 will usually be dis-abled by default.)
Click on #2 monitor and set the resolution to the lowest number (800 x 600 works well)
Then I clicked on "make this monitor my primary monitor"
As soon as I clicked apply the PC Windows screen appeared on the Polaroid TV screen
Earlier I had set the secondary monitor as "extend this screen to this monitor"
This also worked but I had to "drag the current screen to the right all the way off the
"borrowed monitor" until it appeared on the TV screen. The mouse pointer will be there also.
At first it took a little getting used to but in a few minutes I was up and running.
Hope this helps your situation
David Flournoy
Waxahachie Texas
Mar 10, 2008 | Televison & Video
No Display on connecting Data cable of PC
The Monitor is bad, with the CRT Monitors you cannot just replace the connections, because it is embedded into the CRT. So it is probably something that lies with in the monitor itself. Try to connect another monitor to the device. See what the result is, my best guest is the CRT Monitor when bad. Time to replace! Sorry!
Nov 23, 2007 | Samsung 793S 17" CRT Monitor
Computers & Internet Logo
60 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
