Question about Motorola Mobility MD41 Expandable Handset for MD400 Series
Model: MD400Series I have two handset and they will not allow me to dial. I have changed the battery out just a few months ago. But with no success. It's very difficult to press the buttons on the phone. Sometimes they will press, if you press the button really hard they will dial, but most of the time it doesn't work. These are newer phones and not sure why this is happening. Thanks for any help, chris
  • Anonymous Apr 09, 2008
    exact same problem for me, I can no longer dail out on the handset...did the alcohol thing work for you? if not, any other solutions would be helpful...
  • Anonymous Aug 04, 2008
    Well taking the phone apart wasnt easy but i was able to clean the contacts and the phone works great now.
Cleaning the contacts dod fix it. However, be careful when trying to get the phone apart.
Posted on Aug 04, 2008
Was the device made in China? If yes then have it replaced for one made in USA.
Posted on Feb 24, 2008
The electrical contact behind the buttons need to be clean with rubbing alochol and a q-tip.
Posted on Mar 29, 2007
I purchased an extra handset to a AT&T uniden E2125 system. The phone instructs me to place new handset on main base to register handset. It has registered and now it reads, handset #5. When I try...
I've pulled up the user manual for your phone. Thank you for providing the phone make and model first, and the complete description of your issue!
The manual says the battery should be charged for 15 hours before first use.
You may be set to pulse dialing , even though the factory default is for tone dialing. If you push the 7 key, you would hear 7 pulses or clicks in succession. The dial tone will be gone once a pulse has been received. And you say there are clicks heard and no dial tone.
You can set Handset settings (Page 12 in the PDF copy) and customize how your phone works.
Hit MENU and use the up-arrow and down-arrow keys to scroll to the desired feature., this time called DIAL TYPE, then his SELECT. Looks like the sixth menu entry from the top after LANGUAGE.
It should read:
DIAL TYPE
TONE
If it says something else, perhaps PULSE, use those arrow keys again to change the Dial Type to Tone. Then use OFF to back out of the selection and again to clear the menu.
Attached is the link to the manual. Click the button on the screen to "Open as PDF" and you can open it in your PDF reader software or save it to your device for offline reading.
http://phone.manualsonline.com/manuals/mfg/att/e2125.html
Jan 07, 2018 | AT&T E2125 (650530003738) Cordless Phone
Had this phone for many years, love it. couple of days ago it started to have a fuzzy noise but i was getting a dial tone. it will not dial out from the handset but it will dial out and connect from the...
If it only works in the base then it can be said that it only works when plugged into which means it has a battery problem. Rechargeble batteries expire after 1-5 years depending on their application and usage. I recommend that you replace the battery in the handset.
Oct 12, 2010 | Cell Phones
I am having problem with my cordless phone.
Another tip is to remove the battery from the handset for at least 5 seconds. You might want to get a voltage meter and check the voltage on that new battery - maybe it isn't charging properly.
Mar 13, 2009 | Uniden Cordless Phone
How tomake outgoing calls with my american telecom digital cordless phone model#ra23634H
Thuis was hard to find but it worked for my ra2364hh's
note the phone stopped working in "tone dial" after 2 months and now functions with "pulse dial" only.....
Registration The handset and base will be pre-registered with a digital security code identification, which is stored in the phone’s memory, so that your phone will be ready to work right out of the box. However, your phone also has a procedure to allow you to re-register in case the link is lost accidentally. Enter menu, press the key - Select REGISTER and confirm PIN CODE will be displayed, enter the PIN code (the default value is 0000) and confirm. SEARCHING will be displayed while your handset is in registration mode Press and hold the Page key for 3 seconds on the base until the “In use” LED is ON, putting the base in registration mode SUCCESS will be displayed. This means the handset has located the base, and will get a handset number from the base that displays after the handset name for internal calling. If the handset does not locate the base, FAILED will be displayed and it will return to the non-located display mode that displays BS SEARCH with the antenna icon flash. Try again and check that you are not in an environment with interference. Note: Your base can register up to four handsets. If you have more than one handset, repeat the above steps to register each new handset.
TESTED IT 2 minutes ago and it WORKS.....
tony
Feb 23, 2009 | Lands Phones
No dial tone
no dial tone. the handset shows "searching".
Nov 08, 2008 | Uniden Cordless Phone
No connection
deregister headsets and then run register again
Jun 09, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
Handset for ATT 5.8 GHz Cordless Telephone Model 5870
i have at & t 5870 cordless phone it is no t working. handset is dead i change the battery but still not working .please give some advice.
Mar 16, 2008 | Lands Phones
Vtech,5.8 3-phone w/digital recorder, model DS4122-3 None of the phones work they either say connecting or put back in the charger . these are only 2 months old?
To deregister ALL handsets:
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
REPEAT THE REGISTRATION PROCEDURE FOR EACH SYSTEM HANDSET.
Make sure the handsets are not receiving interference from other appliances, cell phones, etc.
IF deregistering does not work .. you will need to reset the entire system
Step 1: Disconnect the power to the telephone base.
Step 2: Disconnect the handset battery.
Step 3: Wait a few minutes and then reconnect the power to the telephone base.
Step 4: Reconnect the handset battery
Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again.
You will need to set the time and date again after resetting the entire system.
Mar 11, 2008 | Lands Phones
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Can only dial 9 or 1, 2-8 keys not working
it sound to be block but thats my personal opinion due that I dont work with that brand, there are few other brand model that have that feuture just to have controls of the use of the phone, they use to recive only but allowe to call 9-1-1..unles no other tech tell you something else try to get the manual of that unit..good luck
Jul 27, 2006 | Vtech VT-2431 Cordless Phone
Open Questions:
Motorola Mobility MD41 Expandable Handset for MD400 Series Logo
168 people viewed this question
Top Motorola Mobility Lands Phones Experts
R.A. Ellis
R.A. Ellis
Tom Chichester
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
