Question about Husqvarna Chain Saw 20" Bar
Can't get it to start
I have 18"husqvarna chain saw.i took it to the shop to have it repair,it started one time and stop.could you tell me who to repair it.
  • 181 Answers
What shop did you take it to.if you took it back to where you bought it from it could be anywhere.make sure the saw has comperssion.easyist way to tell if you have good compression you need to take the muffler off and look to see if the piston is scored.Call husqvarna hot line and they will give you the nearest husqvarna dealer to repair it correctly.
Posted on Jan 09, 2009
Was using saw ran fine stopped and returned next day will not start fuel fine new plug filterers gas and air still wont start took to local chain saw repair shop they said that because it had water in gas...
check the carburetor. If you have a stiff diaphragm then it won't run.
I have seen them that behave just like that. They will run fine, turn it off for a few minutes then they won't restart. WD40 isn't going to get it to run either, try a small amount of mixed gas right into the carb. It should run for a minute until the gas you put in runs out then die. If it doesn't run then you have a bigger problem
Jan 30, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 450 e-series 18" Chain Saw will not
Is this machine mechanically sound, remove the muffler and take a look at the piston through the open exhaust port, any signs of scuffinf or damage to the piston skirt and the saw will have to come apart for further investigation.
Oct 04, 2011 | Husqvarna 450 e-series 18" Chain Saw
My 435 Husqvarna chain saw runs great but on hot summer days when I turn it off and go to restart it 10 min later it will not start. had the same problem with it last summer and took it into the local...
The carburettor is getting too hot and fuel is being blocked from feeding into the engine. Make sure that the carburettor is clean and has adequate cooling while the engine is running. If you still have problems withs starting, blow the carburettor cool or use a damp cloth to cool it if starting is a problem.
Jul 13, 2011 | Husqvarna Chain Saw 20" Bar
I have the same problem with my 350 Husqvarna chain saw. I took the saw to a licensed Husqvarna Dealer. The dealer said that there was noting wrong with the saw. The dealer did clean the carb. I brought...
The temperature is not that different. Is there a fair change in altitude between the dealer and where you live? The jet screws have 'D' heads to prevent owner tampering--how did you adjust them? You need to allow the engine to warm up before pulling the throttle. Make sure the fuel mix is fresh and mixed 50:1 with synthetic chain saw oil--be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. It has to be the manufacturer's problem because it is under warranty. It sounds like the jet screws are set fairly lean. Ask the dealer if you can buy the special 'D' head screwdriver to make your own adjustments. Hope this helps!
Jan 09, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Chainsaw ran out of gas. Filled tank will not start now. Husqvarna 450 e=series 18"
Those saws are very finicky. First shake the saw very vigorously, as the saw running dry mayy have sucked dirt to the intake screen. Clean the plug and check gap. Prime, choke and pull till it starts. your plug may be foulled, this happens alot when a saw leans out from running out of fuel.
Jul 22, 2010 | Husqvarna 450 e-series 18" Chain Saw
353 husqvarna chain saw won't start.
did you try adjusting the throttle cable? does it start at all then die ?
Feb 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Wild Thing-(18")hard starting
I own the Poulan Chain Saw the Wild Thing. Replaced the spark plug and fuel filter and made a fresh batch of gasoline mix and I am still having a hard time getting it started. I had the exact same problem last fall. Repair shop told me it was flooded. If this is the case how do I resolve the problem. I took the plug out and it was dry.
Thanks,
**** Hansen
Oct 30, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Husqvarna chain saw oiler
My Husky 36 did this. The oil pump drive gear was stripped and had to be replace. It's located under the flywheel/sprocket so you have to pull that. I couldn't find info on how to do that so had a local shop repair it for $70! Parts are cheap, labor is not.
Oct 22, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
122 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
