I have the same problem. The thermal fuse inside the unit is showing signs of a slight burn and will not conduct electricity. What are the odds that I would be able to obtain such an item without breaking the bank? I have the same problem. The thermal fuse inside the unit is showing signs of a slight burn and will not conduct electricity. What are the odds that I would be able to obtain such an item without breaking the bank?
You can't post conmments that contain an email address.
Discover the L4.709.2.21.7 quartz watch from the La Grande Classique de ... and let yourself be charmed by its stainless steel and yellow pvd coating strap.
US$1,300.00 · In stock
hi I have just repaired the front of a 2001 sonata classique to remove the headlight assembly remove two screws one one top on radiator bracket one on side towards grill gently wobble to remove from locating pin, to remove just globe unclipcover on back of assembly them unclip globe from inside simple task
cheer chris
Set the oven thermostat to 100 degrees ( very low heat) and wait to see if the onen indicator goes off. If it doesn't then the oven thermostat may be faulty. If you have an oven thermometer, then use that to check the oven temperature.
