Question about Whirlpool AD50USL Dehumidifier
Ground fault interrupt (GFI)
Unit has operated without any problems for over two years connected to a GFI circuit. Now the unit trips the GFI. No evidence of dirt build-up on the coils. GFI does not appear to be faulty as other appliances (shop-vac) operate OK without tripping the GFI. Unit operates OK when plugged into a circuit without a GFI and does not trip circuit breaker. This is not a satisfactory solution because I want to use the unit in a basement where all the outlets are GFI circuits.
  • Anonymous Sep 29, 2008
    Same problem with a 50 pint Kenmore dehumidifier. Unit worked for three or four years with a GFI basement outlet. Now - trips GFI every time after the unit runs for a couple of minutes.
  • jim_taylor3 Oct 25, 2008
    Any solution? I have the same problem. It's been in our basement working fine for 2 yr. Now it trips the GFCI within a minute of starting up.
    Problem Solver:
  • 7 Answers
I have a Whirlpool Model AD$)DSR1 Dehumidifier, with similar issues. When plugged in where it was operating for three years with no problems, it would trip the gfci within 10 minutes. I have it out in the garage right now with all the covers off, and I've had it running on a heavy duty outlet for about a half hour now. The compressor is too hot to touch (ouch!), and the condenser coils are only cool, when they should be quite cold. I am ready to judge that one of two things has happened: Either the compressor is bad, or the refrigerant has leaked out of the system.
Posted on Aug 27, 2009
  • 26 Answers
MOST APP/ THAT HAVE MOTORS OR COMPRESORS CANT BE CONNECTED TO YOUR REG-HOME GFI'S THEY ARE 15AMP AND TO SENSATIVE THEY WILL TRIP EVERY TIME THE VOLTAGE GOES UP AND DOWN . LIKE YOUR FRIG OR WASHER OR DRYER WILL DO THE SAME. PLUG IT INTO A REG OUTLET THAT IS NOT SO OVERLOADED WITH OTHER STUFF.
Posted on Feb 01, 2009
I'm testing my daughter's dehumidifier that blows her fuses. In my house, it does not blow my circuit breakers but does trip my GFCI outlets. What do I need to do?
If you are blowing fuses and GFCI's your compressor is either not starting at all, is starting hard, or is at least grounding out momentarily...
at any rate the compressor is failing, and that is not economically replaceable..
heatman101
Sep 25, 2011 | Maytag M7DH65B2A Dehumidifier
My soleus dehumidifier keeps tripping my fuses on my powerstrip so we have to keep resetting it. Why?
If it is a GFI protected powerstrip then you likely have a ground fault issue, otherwise the powerstrip may be overloaded (unit should pull around 5 amps on startup) or faulty.
Sep 25, 2011 | Soleus CFM-40 Dehumidifier
I have had the Whirlpool GOld dehumidifier for 4 years. It was working great. Recently, I noticed that it stopped working. When plugged it, it trips my GFI socket. I have tried various outlets and checked...
Obviously, there is an electrical short within the unit. Should it be repaired? Yes, if you want continue using it. But, is the cost of troubleshooting, finding the necessary part and repairing it worth it? Most of the time, the cost to repair a dehumidifier is about the same, as what a new one would cost. Now, if purchased an extended warranty, when you originally bought the unit 4 years ago, then you're probably covered for the repair.
In the end, the decision is yours to make.
May 26, 2011 | Whirlpool Dehumidifiers
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
Dehumidifier trips ground fault outlet and no water in bucket
The compressor is trying to start and pulling high amps which trips the GFI...
You are better off replacing rather then repairing that unit.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 17, 2010 | Haier 45-Pint Dehumidifier
Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
heatman101
Apr 16, 2010 | DeLonghi DE500P Dehumidifier
My Fedders A7DH45B2A dehumidifier (about 4 yrs old) continues to trip the fuse embedded in the outlet on the wall in which it's plugged in.. What gives??
either try a different outlet to see if the G.F.C.I. is bad on this outlet or if the dehumidifier trips on another line it could be the units motor start capacitor that shorted or the compressor is bad
Apr 06, 2010 | Fedders A7DH45B2A Dehumidifier
Knocks out house curcuit breaker and stopes running. Use to work fine and did for at least two years now kicks out breaker after running for a while. Have moved it to different circuits and still does it....
You will need to put an amp meter on the compressor wires and monitor the reading till it trips the breaker. If the reading exceeds the name plate spec then chances are the compressor is going bad.If the spec is in watts, take your amp reading and multiply it by 120 volts this will give you the wattage of the compressor. For a second opinion take it to repairshop to see if it is worth repairing.
Good Luck!
Aug 15, 2009 | Maytag M7DH65B2A Dehumidifier
AD50USR Whirlpool Dehumidifier trips circuit breaker
Not very likely check your paperwork what warranty did you get when you purchased this unit? you might have completed some papers and returned them to an address for the warranty to be accepted. It sounds to me like the unit is going straight to earth when switched on, this looks like a compressor fault, but would have to be checked to be sure.
Jul 20, 2009 | Whirlpool AD70USR Dehumidifier
Whirlpool AD50USL Dehumidifier Logo
1,567 people viewed this question
Top Whirlpool Dehumidifiers Experts
Marvin
Marvin
Mike
Gil Shultz
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
