Question about Mitsubishi WS-73907 TV
Mitsubishi ws-73907 turns on then off after 3 sec.
What to do for fixn?
3 Suggested Answers
  • 308 Answers
SOURCE: Mitshubishi WS-73907 won't stay on
I suspect you may have a short in the horizontal deflection circuits or High Voltage transformer. If the set had a "great" picture, it may be worth fixing providing you aren't planning to upgrade to a HDTV anytime soon, otherwise I would use this excuse to start looking for a new set. Worst case I can envision with this set would be one of the picture tubes having a Short, keeping the set from turning on. That would make it unreparable.
Posted on Aug 03, 2008
localwonder
  • 6784 Answers
SOURCE: Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Posted on Feb 19, 2009
MrMojoRisin1
  • 412 Answers
SOURCE: I want to buy an
hi. You can use a VGA cable and a VGA- HDMI adapter or one ot this (click here) .
Posted on Aug 29, 2011
The picture wont come on, power is on but screen is black
this a lack of RASTER, TEST AND measure a) , fuse, c. breaker, transformer, filter, diode, rectifier, IC voltage regulator +horizonta output transistor, HV rectifier, and Flyback HV.
God bless you
Oct 11, 2012 | Mitsubishi WS-73907 TV
Screen wont come on
is lack of RASTER , test the complete POWER supply: fuse, c. breaker, filter, transformer, IC regulator voltage, horizontal transistor, HV rectifier, + FLYBACK .
God bless you
My power button don't work.my timer light blinks.how can i get it to come on.can i turn it on by cable box. or what.
Download the service manual to your set. It will have all details. blinking of standby light is fault codes. These codes and repair proceedings will be detailed in the service manual.
Jun 04, 2012 | Mitsubishi WS-73907 TV
Convergence is way off, Rt & Lf side of screen has red & blue around objects
Convergence IC's inside of your TV have to be replaced. Also some low value resistors around IC's could be burned as well.
Then convergence have to be realigned. This job require above-average soldering skills and cost around $300 if you hire TV repairman to do that.
Regards.
Russ.
Apr 04, 2010 | Mitsubishi WS-73907 TV
Aug 03, 2008 | Mitsubishi WS-73907 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Oval shaped picture problem with Mitsubishi WS55807
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is
Nov 21, 2007 | Mitsubishi WS-55807 TV
HELP
Oct 20, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-73907 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
