Question about Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground
Malibu landscape transformer
The timer won't work. I can manually turn on/off lights. Are there simple checks I need to do before replacing the tranformer?
bernie
  • 2 more comments
  • epankey Dec 13, 2008
    The unit does not keep time. I can only turn it on and off manually. Brand new - it never worked. I am taking it back to the store. Originally, I thought I simply could not locate the timer on/off switch.
  • Anonymous Mar 08, 2009
    I have two different Malibu timers that will not switch the lights on. If I remove the pegs, the timer works fine. However, whent he on/off pegs are installed, the timer stops at teh peg and will notturn the unit on.
  • chazdisc2 May 03, 2009
    I have a ML88T that has this problem. I've removed the timer face and found that the gear linking the motor gear to the timer gear is worn enough as to no longer engage with the motor gear.
    Too bad I have not found this gear to be available. As long as the motor is not burned out, this little gear would solve the problem.
  • Anonymous Mar 14, 2014
    While wiggling my light bulb to see if it would come on, all the lights in the malibu system went out. Power appears to be going to tranformer
  • 44 Answers
If it is keeping time try moving the stops. If it is not keeping time the motor is probably burned out. These transformers don't have a lot of serviceable parts to them.
Posted on Dec 04, 2008
We have a Malibu 300 low wattage transformer for 13- 20 watt landscape lights.
Try connecting a lamp (correct voltage, etc) directly to the transformer. Most likely, the wire from the transformer to your lights is broken... The reset button can't reset anything, if there's nothing wrong there.
Jun 16, 2016 | Intermatic Malibu 300W Power Pack...
Where can I buy a replacement photocell for my Malibu 300W low voltage landscape lighting transformer?
You can buy the Malibu Photocell Low Voltage sensor on eBay. Go to eBay and search "Malibu Photocell Sensor" and you should see it. Or search eBay item number 371829265599
Mar 26, 2016 | Intermatic Malibu 300W Power Pack...
Problem with Malibu Landscape Lights Transformer ML900TW
Use an extension cord to plug the transformer into a different "test" GFCI receptacle, if it holds on the test GFCI you know that the GFCI for the transformer needs replaced. If it doesn't hold, then the transformer is on the way out and should be replaced. Sometimes motors and transformers will "leak" current and still work, but not trip a regular circuit breaker. A GFCI that is doing it's job will catch it though. Don't force a GFCI like that...you can wear it out prematurely.
Apr 24, 2012 | Home
We have an outside landscape light time that has quit working. Model pb115m1. Do you carry these?
Fixya does not sell timers or parts.
Timer system is not identified for certain.
If landscape system still turns on-off with override switch, then you can work around and buy cheap plug-in timer, set landscape to override, and plug landscape system into cheap timer.
Open following link for low voltage transformer resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment for more help.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 28, 2011 | Hardware & Accessories
I bought a Malibu 300W low voltage landscape transformer to replace a 200W unit that stopped working. It worked for 1 week, then stopped .. the reset **** doen't work. The LED works, I do see a...
I don't know if it burned out, but something is not right.
Malibu products come with 1-5 year warranty.
New product that stopped working should be exchanged for full replacement at place of purchase, except possibly the auction sites.
New Malibu product should work for many years.
Be sure to match bulb voltage with transformer voltage to avoid possible problems.
Mismatched bulb and transformer wattage should not affect a timer in short period such as 1 week.
Another thing to check is outlet polarity. Use circuit analyzer from home center to check outlet.
Jul 20, 2011 | Intermatic Malibu 300W Power Pack...
Need the on/off (red/black) pins to set on/off times on a 9yr. old Malibu landscape lighting transformer. Simple, where I may procure these pins? This is not a trick question.
Yours is a frequently asked question... twice today
I don't see Malibu tripper pins anywhere on the internet or at Malibulights.com
The newest Power packs are digital and don't have tripper pins.
Oct 13, 2010 | Hardware & Accessories
Lights will turn on and off manually only
Just checking, still plugged in, fuse or circuit breaker not tripped that provides power to it? If you can turn it manually, and the dial does not turn when powered up, look for a small on/off switch, other than that, maybe it does need replacement, but they usually last longer that a year, but I have had some timers that just quit working on me too.
Apr 29, 2010 | Intermatic Malibu 300W Power Pack...
I discovered that I hadn't turned the manual switch to off on the one that wasn't working properly.
Now they both work fine. The instructions that come with the Malibu Transformer is not easy to understand and it does not go into enough detail. There isn't a trouble shooting section which would help.
Apr 14, 2009 | Intermatic Malibu 300W Power Pack...
Malibu ML600TW - Low Voltage Power Pack - 600 Watt - With Timer and Ground Logo
2,176 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
jdthefixer
 Kenneth
Kenneth
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
