Question about Canon PowerShot S45 Digital Camera
Lens cover is stuck
The lens cover started being "rough" and "bumpy" when opening it ans sometimes became a little bit stuck. THen later on it just became stuck open - I could not move it anymore and therefore also no longer take photos. I solved this and will post the solution now.
  • 4 more comments
  • Benjamin Franzmayr Sep 07, 2006
    The problem was that one of the two very small gears in the lens cover had split into two pieces and had caused the lens to become stuck. I did this repair a few months ago so my memory is a bit hazy on the details!
    I removed the front cover of the camera, unscrewed/took apart the various bits that hold the lens cover in place (be careful to note how they fit together and don't lose the spring in there), removed the lens cover (I can't remember exactly how it came off, sorry) and found one of the little gears in two pieces.
    I used shock resistant superglue to glue teh gear back together and onto its metal shaft. I did this with the gear in place. Left it to harden overnight and reassembled the camera.
    The lens cover is not quite as smooth as it was before the problem but it works again so I'm happy!
    One note - be careful not to short-circuit any of the circuit board tracks or anything - I managed to destroy another camera by doing this. There was a little backup battery somewhere with which I managed to fry something. Just be careful.
    This is a slightly fuzzy close up of the mechanism. Actually I think there is another very small spring in there as well as the one visible.
    And here is the lens cover, removed with the offendinggear in two pieces at the top. The lower gear is OK. You can also see the plastic running along the middle of the cover - this is what the mechanism slides on and you don't need to remove those 3 screws.
  • Anonymous Jan 02, 2008
    how to remove lens cover?
  • boyacks Jan 02, 2008
    how to remove lens cover of my Canon PowerShot S45 cause it stuck and the lens does'nt move?
  • wbobadilla Jun 26, 2008
    my cover will not slide properly...not able to take pics.. does not engage the lens
Thanks for your help
Posted on Jan 02, 2008
    Problem Solver:
  • 17 Answers
I did the same repair...however, I found that those little wheels are completely optional. All they do is keep the lens cover from prying away from the camera, but if you're careful, the lens cover will work without them.
Posted on Dec 09, 2007
  • skinful Nov 14, 2010
    I have just completed the lens barier repair. I purchased a new barrier from a canon authorised dealer and using the parts cataalog here -http://www.micro-tools.net/pdf/Canon/POW... SHOT S45.pdf - disassembled and reassembled with apparent succes 'gos it works just fine.
    Mike
SOURCE:
Lens cover sticking
Stuck automatic lens cover is usually a very easy fix. A lot of times it's just a bit of gunk or dirt jamming it. Pay attention to the paper or vacuum fix. Do not recommend opening it as it is somewhat complex (tiny springs and shutters).
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 21, 2013 | Canon Cameras
I dropped my camera while it was on and the lens was in the process of extending- the camera hit on the lens and now the camera turns on' there is a little motor noise and the screen lights up and says...
Get another camera. Just like a car that is involved in a major collision, it will experience many other problems later that currently will not appear. You will probably spend additional money to fix subsequent issues later. An average camera repair will range up to $100.
Dec 16, 2010 | Nikon Coolpix L11 Digital Camera
Any advice on a sticking lens cover on the canon G7
This blog post outlines repair procedures for stuck lens covers. Recommend trying reader "Jeff's" fix first shown in the comments section.
Jan 20, 2010 | Canon PowerShot G7 Digital Camera
Lumix dmlt55 telelens, the ring inside is not fixed
As it arrived in a broken state, return it for a full refund.
Jul 22, 2017 | Panasonic Cameras
Panasonic Lumix DMC-TZ3 Lens Won´t Open
This is a common problem with TZ3s. Power the camera on, then puff a little graphite onto the lens cover and coax it open with a tooth pic. Do this, powering the camera on/off till lens opens normally. Add little more graphite if necessary, but sparingly.
Graphite is used because it is extremely slippery, but will not attract dust like an oil will. At the same time, it is black! so you don't want to use anymore than absolutely necessary make lens work. Even then, check to be sure lens itself is clean after, and wipe carefully with an Eyeglass lens cloth only if necessary.
Another option in to remove the lens cover altogether by just pulling the leafs out of the camera. Another option is to sell your working but lens cover problem to a repairman on ebay, and buy a good TZ3 or TZ5 on ebay used, refurbished or new. Good prices if you bide your time.
Don't put in your best bid to the very last minute of the auction. In the mean time, put a camera you are interested in on your MyEbay Watch list and set a reminder alarm on your cell phone about 5 minutes before the auction is to close, then if the price is still good, enter your best bid 30 seconds before the end of the auction. Refresh the auction page on your PC to keep track of the bidding right up to the last 30 minutes so you can see the last remain bid and if it is worth outbidding on this camera. Again, if you are not in a hurry and bide your time, you can get a great buy. There are plenty of these cameras sold every day.
Jul 27, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens shutter stuck
If you're careful this problem is a relatively easy fix for many digital cameras. The design of the lens cover mechanism is usually simple and very similar throughout camera brands. Here's an example fix for a Canon A400 with similar problems:
Jan 24, 2007 | Fuji FinePix A340 Digital Camera
Lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
Jan 16, 2007 | Casio Exilim EX-Z120 Digital Camera
Canon PowerShot S45 Digital Camera Logo
884 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
