Question about Brother HL 5250DN Laser Printer
Driver network printing driver needed
    Problem Solver:
  • 7 Answers
What do you mean by Network Driver? You simply use the standard Brother Driver and assign the port as an IP/TCP port! The Windows help can give you advice on this.
Posted on Dec 01, 2008
Hp deskjet 550c trying to print from network But I am on windows 7. Printer is on xp. Can't find driver or fix to run printer on network
Use my published guide to install the latest drivers for all computers on the network. It is entitled
How to Install the latest drivers for Hewlett Packard Printer!!!
The drivers need to be installed on all computers in the network.
Then once the drivers are installed all you need to do is to navigate to the Windows control panel and double click printers and faxes on the computer that the printer is connected to.
Now right click the your printer and select the option Sharing, this will allow you to share the printer on the network.
Click the lower circle to share the printer.
Then when you print from another computer on the network, be sure to select this shared printer as the printer to print to, or set this shared printer as the default printer by right clicking the printer and selecting the option to set as default printer.
Please be sure to rate this session.
Take care!
damnor01
Jun 01, 2011 | HP DeskJet 550c InkJet Printer
My printers and cash drawers (printers on the network) won't function. All of them work indivudually when test pages are printed. How do I get the network to see them?
please cheak the following
for printer to weork in the network you need network ,network printing sharing driver, or apllication of printer i.e. software you are using it should share the network.
please cheak the following thing
cheak if you have a network then rj45 cable is attached or not on computer side .cheak it is blinking grren &orange light. green is for power &orange light is for data transfer
cheak you have shared your printer driver for network printing
cheak your software is compatible with network printing or not
waiting for your reply
thanks &regartds
vijay p. patel
Apr 06, 2011 | ACM Supplies POSMicro Premier Retail...
Xerox 5500DN Phaser PCL driver installed and printer and IP recogized with web printing Prints setup and help info from printer panel pefectly Paralell or IP printing from PC Host only dumps hex output...
The printer is printing in hexadecimal the binary data it is getting over the network as it does not recognize the print stream correctly. Likely reason is that the print stream originator which would be a PC trying to print to it is using the wrong driver. Could try connecting the printer directly to the PC in question and installing it as a local printer then trying to print to it directly. If the result is still a hex dump, then the drivers are incorrect. Usually the drivers not only have to be the ones for the printer but also must be tailored for the PCs operating system as well. If you can get the correct drivers for the PC and can get it to print correctly on the Xerox, then the Xerox can be reconnected to the network and re-installed as a network printer (delete the old network printer first) on the PC. During the installation of the network printer on the PC, do a final test print to check.
Mar 18, 2011 | Xerox 5500/DT Laser Printer
How to connect the machine to the computer for printing
Be sure that you have network option installed. On top cover of the printer itself (under the scanner) you can see a floppy drive, can you? OK, then it is capable of network printing. Also parallel (Mini-Centronics) port will work.
You may try parallel printing first, it is easier. Download from
www.xerox.com/support drivers for your DC440ST.
Install driver. Connect parallel port to computer via Cenntronics cable and you'll be ready.
If you want to print from network you must have UNIX printing installed in Windows. You have to create a new port in the printer driver and create a print queue and name it "lp". Port address is also needed. For example 192.168.0.1.
To set up network address on the printer you have to log into the printer as administrator.
Press (key) button on the top right part of the keyboard.
On the touch screen enter: #22222 (hash sign and five 5's)
Enter "Networks settings" "TCP/IP" "network address" "STATIC" "192.168.0.!" for example" "SAVE" "QUIT" and the printer will boot.
You may have to ping for the network address to see if it responds. If the copier/printer prints out a config sheet in five minutes you can check the address and other setting you just did.
If the printer DOES NOT PRINT the config sheet it may be disabled in settings. You can log in again (key) #22222 and enable "print config sheet" + reboot again.
Sep 08, 2010 | Xerox DC440ST Copier
Print spooler unable to connect tp printer,cable
Print internal configuration page and check for IP address in printed sheet and try to compare with the driver information
Check for LED at network card if it’s on
Try to send ping command to IP address to verify connection and if reply is confirm
Uninstall driver and reload and try to search the printer with IP or hardware address while loading driver
If still any problem it could be network card have problem need to be replaced
Nov 07, 2009 | HP Color LaserJet 2600n Printer
Connected ir3300 to network. Can ping static ip address. the PS3 print driver install detects the printer on the network. Printing fails - print times out every time. Tried installing printer on Server...
Did you just install a NIC (aka ethernet port) in your copier?
To print Network Multi PDL Printer Kit C1 needs to be installed. This contains the NIC and the N Boot-Rom. The copier then needs to be upgraded with networked firmware using SST.
Go into Service Mode (Additional Functions > 2,8 > Additional Functions). Go to Copier > Display > Version. Check the number for BOOT-ROM. This should have a N at the end. If not you need to replace the C BOOT-ROM with a N BOOT-ROM.
Also under Copier > Display > Version check the number for PS/PCL. If this is blank then you don't have printer drivers installed on the copier. You will need to get a technician to come out and upgrade the firmware on the machine.
Aug 17, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
I install konica bizhub 350 to my network. scanning is going to SMB and very nice, but when i want to print from my PC, it did not print and also give no error.plz immediate help necessary. envoirment is...
Reinstall print driver to the PC using same ip address and print test print. next the same procedure go to web browser enter the ip address and choose administrator and the password 12345678. all your question will be in that area. scan, printing and network.
HH
Aug 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Can't print from my mac to my canon mp980 wireless printer
Sounds like when you added xp you inadvertently installed new print driver on server.
Try rolling back driver. But may drop xp from printing.
Best solution network printer to router bypass server. Will require hard wire from printer to router. disconnect from server may need network card for printer.
Mar 08, 2009 | Canon PIXMA MP980 All-In-One InkJet...
We buy canon copier ir3035 with all acces,every thing is don but we cant install properly pdl kit,because its not accepet printing from networking or we tray to print through usb port as will after install...
(This is for your information)First ur problem is not mentioned clearly. You are mentioning network printing is having problem (this is ok) but it is not clear that printing from USB is having problem or not. And you did not mention the type and version of your operating system(OS) and the nature of your network. Installing driver is very crucially depend upon the OS and the type of network that you are having.
Let assume that you are having genuine MS Windows 2003 Server as the backbone of your network and genuine MS Windows XP SP2 as the OS of the client PCs. Some basic knowledge of networking is required to understand and execute the remedy mention below. And you should read completely first before trying out this.
For network printing problem of Canon ir3035, first check the physical network cable(UTP) if it is properly crimped & properly connected, then check the connectivity by pinging the IP of the copier (which is needed to set manually if there is no DHCP server in the network). If the copier is responding properly. Check again by pinging the server from the copier (which you will find under MENU and NETWORK OPTIONS of the copier). If both the way is responding properly uninstall the printer driver totally and restart the system. Re-install the USB driver first and then re-installed the network driver (before re-installing the network driver first check whether it has got the required IP from the DHCP server, if not assigned one according to your network). If there is no error message during the installation of the USB driver(normally USB installation does not show any error), USB printing should be ok. Thus USB case is close.
Then check the network by using the same procedure mention above. If everything is ok, you can carry out the installation process for network driver. This way there should be no network printing problem. If still there is the problem please check that you are not using pirated copy of OS. Network printing for ir3035 is not ok if pirated copy of OS is used. You have to get a genuine copy and will solved the problem A to Z.
Jul 24, 2008 | Canon Office Equipment & Supplies
HP Laserjet 3050, 2605dn, 1022n
One time un reinstall the all printer drivers Before u go to C:\WINDOWS\system32\spool\drivers\w32x86.then delete all folders and files
Apr 08, 2008 | HP LaserJet 3050 All-In-One Printer
Brother HL 5250DN Laser Printer Logo
99 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
