My DVD drive has a SATA cable (I think) and not the regular IDE cable. There doesn't appear to be any slot to insert the SATA cable into the ASUS 845 mainboard I purchased.
-   Ive got the same problem, because i just bought a DVD with SATA connection but i would like to know if my motherboard ASUS P4P800 SE can support a DVD drvive with Sata connection, Here are the characteristic of my motherborad:
P4P800 SE
ASUS Intelligence Everywhere
- Intel 865PE Chipset -800 MHz FSB -Dual-Channel DDR400 Memory -Intel Hyper-Threading Technology -ASUS Intelligence Features -Wi-Fi slot for optional wireless LAN upgrade
-   Pic21
I'll need a better model number than "845" to give you a definitive answer, as ASUS doesn't name their boards that way. I suspect that the board supports the Intel 845 chipset and that's where the 845 comes into play. If you don't have the owner's manual, you'll need to look at the board real close; you'll find the model number stamped on the board. The good news is that if the board was built in the last 3 years or so it should have built-in SATA connectors (at least 2, probably 4 or more). If your DVD doesn't have the IDE cable and instead has a much smaller cable, it is in all likelihood SATA. In the worst case, even if your MB doesn't support SATA, you can buy a SATA PCI card to hook the drive up to for under $30. Finally, you can go to www.asus.com when you get the full model number. From there you can download an owner's manual that will have the SATA ports labeled.
I hope this helps you. If you think it appropriate, a fix-ya rating would be much appreciated.
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS...
(More)
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS your views on these boards as to building your own computer etc?
I got k7d ver 1 mb and its not booting when i use two cpu. its switch on and imediately cut the...
(More)
I got k7d ver 1 mb and its not booting when i use two cpu. its switch on and imediately cut the power then i cant boot until i take the power lid for 30 sec. I have tested only primary cpu slot working, and when i use one cpu at sec cpu slot it stays power on but no display on screen. so i have to use only one cpu....an reason or explanation what gone wrong. thanks
is there any way to format a laptop without a battery?I have a hp compaq.the problem is i tried to...
(More)
is there any way to format a laptop without a battery?I have a hp compaq.the problem is i tried to format it and install a new operating system in it. but after formating and copying all the necessary files and have to restart, it goes off and have to start the whole process again
