Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Baseboard heaters want to run 3 or 4 off same stat what wire should i use 12/2wg or 10/2wg
  • patio492 Oct 30, 2008
    no answer yet
    Scholar:
  • 145 Answers
I can answer this if you are still here.
Posted on Nov 06, 2008
Honeywell rlv430 is wired in correctly, yet one baseboard heater is always on, regardless of the temp Its set at
Need to start with comparing the temp in the room to the temp the heater is set to. A t-stat will read +/- the actual temp. If their not even close, then the heater will run trying to reach the temp the t-stat is set to.
Mar 06, 2011 | Honeywell Programmable Thermostat Heater
Do you have a pic. of how i hook thermo to my marley 72 inch baseboard heater , i have the mdl. fta1a the instructions show line 1 and 2 , but i have two wires on the left front that are hooked to the...
Two wires to the T-stat should go to W and C which is W for heat call and C represents common!
When the T-stat is set to heat it will connect the 24v red wire to the W terminal therfore sending 24v to the heater and the common wire completes that circuit. Make sure to use an inline fused wire to test so you do not blow your transformer. Easier to replace a fuse then a T-form
Oct 07, 2010 | Marley Electric Hydronic Baseboard Heater,...
CAN I WIRE A 2 WIRE NOMA NON PROGRAMMABLE THERMOSTAT TO A 240 V BASEBOARD HEATER AND HOW. 2 BLACK WIRES ON THE THERMOSTAT. 3600W@240 VOLT
To the best of my knowledge, Noma does not make a high voltage stat (M# would be more helpful). You most likely have a heating only stat that operates on 24VAC. Also, at that wattage, the wires on your thermostat would need to be a minimum of 12ga.
Oct 04, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Problem wiring 240amp baseboard heaters
12 gauge wire sounds under sized for the application. And 20 amp 240 v breakers might be sufficient if you where wiring the heaters separately. But be sure that your wiring is not romex - because romex is an insulator and is not permitted in conduit. I would suggest that you up size your wire to 10 guage and your breaker to 30 amp as well. Then double check your heater wiring connections to insure that they're wired the same throughout.
May 03, 2009 | QMark FBE15002 electric baseboard heater...
How to size a room for baseboard.
HERE YOU GO CALCULATE THE HEAT @ 10 WATTS PER SQUARE FOOT , TAKE THE LENGTH X WIDTH X 10 AND THIS WILL TELL YOU THE AMOUNT OF WATTAGE YOU NEED . MOST ALL BASEBOARD HEATERS ARE RATED @ 250 WATTS PER LEN FT AS TO SAY A EX. A 4FT HEATER IS 1000 WATTS , MOST OF THE THERMOSTATS ARE RATED @ 20 AMPS AS IS THE 12-2-WG WIRE TO RUN TO HEATERS AND THERMOSTAT DIVIDE THE TOTAL WATTAGE BY THE LINE VOLTAGE USUALLY 240VOLT IN US .AND THIS WILL TELL YOU THE CURRENT DRAW ----WHICH CANNOT EXCEED 20 AMPS ON 12-3-WG AND THAT IS THE LIMIT OF THE THERMOSTAT AS WELL THESE STATES APPLY 99% OF THE TIME I DO REALIZE THERE ARE EX BUT HAVE USED THESE FORMULAS FOR 35 YEARS OF DOING MY WORK AND THEY DO FINE
Dec 16, 2008 | Fahrenheat Electric Convector Baseboard...
Wiring for baseboard heater
I hope you are using a Line Voltage Thermostat!! First, make sure that the power feeding the thermostat is coming from a two pole breaker of the correct amperage (20 amp). If you are using 12-2 wire with ground then please mark the white wire with black tape at each end to identify it as a HOT power source and not a Neutral wire (which is a grounded lead). Do the same for the 12-2 wires feeding the baseboard heater from the Line Voltage Thermostat. The wires from the thermostat (One Black & one White w/black tape) will be wired to each one of the two wires (one Black & one Red or two Black wires) at the baseboard heater. It doesn't matter which wire from the thermostat is wired to which wire at the heater, just as long as there is one wire to one and one wire to the other.(eg. Black from stat to Black at heater/White w/blk. tape from stat to Red at heater OR Black from stat to Black at heater/White w/blk. tape from stat to OTHER Black at heater). I have seen baseboard heaters with two black wires or one black and one red wire. Hope this helps, but if you are confused then please have an experienced tech. do it for you.
Dec 14, 2008 | Fahrenheat Electric Convector Baseboard...
Baseboard heater
the stat points are stuck together or the stat is defective. try tapping on it to make them loosen up or replace the thermostat.
Dec 08, 2008 | Fahrenheat FBE15002 Baseboard Heater
Wireringhowto
look up my profile and send an email there. I will provide you with a point to point diagram.
Jan 24, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
63 people viewed this question
Top Fahrenheat Heating & Cooling Experts
paulcarew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
