Question about HP xw8200 PC Desktop
Blinking red lights on startup
What does 4 blinking red lights mean on a hp d530cnt desktop mean?
  • Anonymous Mar 24, 2009
    My new XW8200 HP workstation can't start up. It shows red light and blow whistle. I checked the connection to the hardrive, its ok. I check the fan its working properly. The computer is clean, so there is no dirt inside. I don't know what to do. Is it factory fault or what? please tell me!
    Problem Solver:
  • 5 Answers
If you look up the HP diagnostic LED code on the xw8200, if the red diagnostic LED is blinking 4 times signifies a bad power supply.
Posted on Mar 28, 2009
  • 749 Answers
4x red blinking light on this system means it's "CPU thermal shutdown" this is done when the cpu fan fails to cool the cpu and the computer shuts itself down to keep you from burning up the system.
This could be caused by dirt, hair, dust in the cpu fan or heatsinc or because the fan has failed.
you can blow some canned (dry) air through the fan and heatsinc undernieth it and try to clean it. most likely you will have to take it off to clean it thoroughly or replace the fan. It is about a 15-20 dollar fan and your local computer shot or neighborhood computer guru can replace it in 10 minutes, so dont let then keep your computer longer than a day.
If your computer savy, remove the case, inspect the fan while the computers ON to see if it sounds weird or is not coming on at all. it has usually two retaing clicps the can be difficult to remove with the power supply in the way. so be ready with a philips head screwdriver and a notebook to write down anything you dont want to forget to put back. If you decide to tackle it, post again here after you check the above mentioned things and ill get you a detailed breakdown of how to do it. It real is not too hard.
Posted on Oct 29, 2008
Health lights blinking red
You say the "health lights" blinking red. If this is the power light on the front then it can blink at different rates:-
Flashing red (2 blinks) Thermal event (THERMTRIP#).
Flashing red (3 blinks) No CPU.
Flashing red (4 blinks) Crowbar.
I'm not quite sure what they mean by "Crowbar"
The user manual can be found on this link:-
whilst the link below gives you a list of the available documentation for download:-
Jan 18, 2014 | HP ProLiant ML110 G3 Server
Hp compaq pentium 4 not booting, light blinks red 8 times
No solution, but I can give an idea of what's wrong.
In the quickspecs for this computer
nder the expended Technical Specifications section, in the 'Serviceability Features of the system' section, under 'Diagnostic LED Explanation Table', it says 8 blinks of the red LED, repeated every 2 seconds, mean "invalid ROM, bootblock recover mode"
It seems that your BIOS ROM become corrupted. The solution to this problem depends on which BIOS you have. Search "invalid ROM, bootblock recover mode" for possible solutions. Restting the CMOS by shorting the two pins on the m/b might just work, but I doubt it in this case. You may have to get the contents of the ROM from HP and re-flash your ROM. Good luck.
Feb 23, 2013 | HP compaq dx2000mt pentium 4 2.8g512mb...
My hp compaq doesn't work when i branche the cable of alimentation it signe with red
How many times does the red light come on ? It should blink a number of times, then go off for a little while, and start blinking again. The number of blinks within each cycle will help you find out what is wrong:
Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
Jul 07, 2012 | HP Compaq d530 CMT PC Desktop
I try turning on my hp compaq d530 sff this morning it did not boot and the switch light was blinking red every two or three seconds.
Jun 15, 2011 | HP Compaq d530 SFF PC Desktop
Short beep and red light
Did your Bios Battery Die?
5 short beeps = BIOS recovery successful
Usually means bios has lost settings some how. You have have more significant issues if there was a power surge.
Jan 02, 2010 | HP Compaq d530 SFF PC Desktop
My hp desktop pc wont startup - when i turn iton there are a number of beeps then the light starts blinking red can anyone help?
You need to try and find troubleshooting codes on their website, but the blinking and beeps is actually a code that will tell you exactly what is wrong with it if you know the codes.
Oct 24, 2009 | HP Compaq dc5000 PC Desktop
There are two lights right under the turn-on bottom and one has a picture of a battery and the other is a picture of a light bulb and this light bulb is blinking red five times in about 3second intervals.
the blinking bulb is the speed or the utility of the ram memory ....if it is blinking then it means that ur pc is utilising memory of ram....if it blinks faster then its using more memory....
Jul 17, 2009 | HP Compaq d530 PC Desktop
Computer will not boot or respond
Beeping upon startup is generally a problem with memory ..
Mar 13, 2009 | HP Compaq dx2000 PC Desktop
4 beeps & 4 flashes mean problem with the power supply. For my experience, most of the time the PSU is good, it is just overloaded.
For more LED and Beep messages, check this link:
Dec 26, 2008 | HP Compaq d530 PC Desktop
HP xw8200 PC Desktop Logo
1,406 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
