Question about Kenwood KDC-519 CD Player
My head unit is awkward.
I recently baught a vehicle with the KDC-519 unit installed. The unit flipped down when the vehicle was on, and flipped up when the vehicle was off. The buttons, however, did nothing when pressed. I looked at a product manual online and did a s it said: I pressed the reset button. The display all shut off to do what I thought was a reset, but then it flipped half way open and half way closed. It is now sitting out of my dash looking like a little cup holder and nothing I press or do does anything. What is going on? It flipped before I reset it. I'de also like to get the buttons to work once it actually gets back to it's normal location. Any help would be greatly appreciated.
  • Ryan Patterson Sep 08, 2006
    Would buying a whole new face plate fix this? It would cost me $100 with S&H so i'de like to avoid it if possible, but if it is my only chance then i'de like to know.
    Thanks a bunch! I will report to my local Kenwood dealer for a repair.
    Scholar:
  • 72 Answers
Check the wire braid going out to the faceplate. Although this is a fancy feature. it is very problematic. But usually it looks like a flat plastic strip with brown stipes on it. Sony calls it a flexible circuit board. after so many flips wires break the buttons stop working and when the face gets just is the right place it stops turning. but is repairable if you can order the braid from Kenwood about a skill level five to put in.
Posted on Sep 08, 2006
Kdc-x969, when the unit is tured on the face does not flip down. most buttons turn the unit off but the face flips down instead of up when it shuts off
It very well could be that the internal motor that moves the faceplate is going out or has already gone out. It sounds to me like that could be the problem.
Apr 12, 2011 | Kenwood eXcelon KDC-X969 CD Player
Codigo de seguridad kenwood kdc 519
Try to send one email at " restoredclassic@aol.com " with the vehicle vin number and the serial radio (sometimes need to take off the radio to chjeck in backside).
Keep us updated.
Feb 25, 2011 | Kenwood KDC-519 CD Player
KDC-215S battery drain
You could add a switch to control the power going to the head unit. I have seen this done in many different vehicles where the head unit drains the battery, even when supposedly off.
Jul 19, 2010 | Kenwood KDC-215S CD Player
Kdc-519 install in 93 mustang
if u have cut the factory harness, then u may have cut the power on wire for the factory amp
Jun 07, 2009 | Kenwood KDC-519 CD Player
Kenwood KDC-MP922
there is a button under the back of the face in one corner, just press around the back of the face with the car on until you feel the button press in and it should open.
If not you may have a bad ribbon cable that is not too expensive to replace.
Sep 09, 2008 | Kenwood KDC-519 CD Player
Security code Lockout
I had a similar issue with a head unit in a newer Volkswagen. There was an unlock code burried in the vehicle's owners's manual.
Since your stero is an aftermarket model, I would bet the unlock code is in the manual for the head unit.
Sep 09, 2008 | Kenwood KDC-MPV7019 CD Player
Kenwood KDC-519 Faceplate Problem
Detach the faceplate and look at the electrical contacts on the back of it for damage/dirt - you can spray it with electrical contact cleaner. Do the same to the contacts on the head unit - it sounds to me like one or more of them are a bit loose or otherwise not working properly.
Feb 23, 2008 | Kenwood KDC-519 CD Player
KDC-X869 Face Flips Halfway, Unit Turns Off
I have worked on many of these radios and there is a lever that contacts switch to determine position of face this lever wears out and switch does not operate properly causing radio to lose its mind. This is usually the cause of this failure unless flip gears have been damged somehow. contact kstahl65@att.net for additional info
Jan 21, 2008 | Kenwood eXcelon KDC-X879 CD Player
Cd player locked
It has a defective ribbon cable between the face and the motherboard. This is a common repair, but must be done by a repair shop. My shop charges around $60-70 for parts and labor for that repair, to give you a ballpark of what to expect.
Sep 09, 2007 | Kenwood eXcelon KDC-X689
Check ribbon cable from main board to face for breaks in the lines. Replace ribbon cable if bad.
Aug 01, 2007 | Kenwood KDC-519 CD Player
Kenwood KDC-519 CD Player Logo
118 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
