Question about iRiver H340 MP3 Player
Cannot access files on h340
Whenever i try click on the local disc h (iriver) my computer freezes and after a while it asks to format the disc and i cant get to my files...ive formatted it and i now hav nothing on my iriver and am unable to put stuff on because i cant access the disc....how can i fix this???
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 31, 2008
SOURCE:
My iRiver H340 player is showing the HDD error message "Total: 0000 Folders(s)" after I inadvertently disconnected the player from my PC whilst transferring music. Hence I can't access my music...
There is a chance that the file structure has been corrupted and the player cannot retrieve the directories.
I suggest you saving the files onto your computer and perform a format on the players's harddrive. Use a Windows utility or a programs like FAT32formater, available here:
http://tokiwa.qee.jp/EN/Fat32Formatter/
Dec 28, 2014 | iRiver H340 MP3 Player
Iriver h340 hdd
The only results from a search for h340 is from Logitech, and this is a quote from Logitech support.
"Your Logitech USB headset doesn't require any drivers or software, other than the default device drivers built into your operating system."
If your device is indeed a Logitech headset then you might try this:
Unplug the headset
Click on start
Right click on My Computer
Click on Properties
Select the hardware tab
Click on Device Manager
Look for your headset and uninstall the driver
close all the windows and reboot
after it reboots plug the headset back in, the correct drivers should then install automatically.
Jan 29, 2014 | Computers & Internet
Please tell me where can I get video converter for Multi codec jukebox Iriver h320
Unfortunately, your H320 is great for music, but quite limited when it comes to video files.
The video format specs for Iriver H320 are:
File format: AVI
Codec: XviD MPEG4 (recommend XviD 1.0.2 codec)
Resolution: 220 x 176 only
Frame Rate: 10 or 15fps
Bit Rate: 500Kbps or less
Audio Codec : MPEG 1/2/2.5 Layer3
Audio Bit Rate : 128Kbps, 44.1KHz, CBR
For video conversion, try Pazera's Video Suite or NCH Prism Video Converter; both are freeware.
Sep 08, 2013 | iRiver H340 MP3 Player
Iriver h340 new hard drive will not boot up
There are websites that offer data recovery from a failed drive. That would be your only option here.
Lost Data Call us now
Hard Drive Recovery Services SALVAGEDATA Recovery
May 03, 2017 | iRiver H340 MP3 Player
Iriver h340 shows no content or does not load properly
Sounds like the battery is dead. Rechargeables only last so long. I'd copy all the content off it, before the battery dies totally, which could make it not work even connected to your computer. Looks like you can get a replacement battery: Iriver h340 Google Search
And here's a video on replacing the battery: How to Replace the iRiver H340 Battery
May 25, 2017 | iRiver H340 MP3 Player
IRiver H340 Hard Drive Capacity Problem
The reset button will not delete any file or function, just press that.
When you connect your H340 to PC, you may right click the H340 drive icon, and select 'property' -> clean up drive
Mar 20, 2008 | iRiver H340 MP3 Player
Putiing music on the iriver h340
iRiver has a special DRM signature, and only recognizes certain file formats. iTunes will ont work with the iRiver,for instance. Here are the formats recognized:
MP3 file
: WMA file
: OGG file
: ASF file
: IRM file
What is IRM (iRiver Rights Management)?
The IRM is digital copyright information file designed by iRiver
Limited. The IRM technology protects copyright and property from
unauthorized usage of digital contents provided through iRiver
Limited.
Use the proprietary software found on the IRiver website to transfer songs. If they still won't play, run the songs through Media Monkey or another Mp3 Converter to make them playable.
-Tha Mp3 Doctor
Mar 13, 2008 | iRiver H340 MP3 Player
New Music files copied to my iriver will either not play or partially play
Backup the h340 to your pc, format the h340 hdd and reload it, refresh database.
Oct 17, 2007 | iRiver H340 MP3 Player
How do I put movies on my iriver H340
you need to use the software provided to convert the video files.
Aug 21, 2006 | iRiver H340 MP3 Player
iRiver H340 MP3 Player Logo
106 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
