Quasar up1762uj power cord dc
Can you tell me what pins the dc 12 volts are connected to this tv?
thank you
franbarb
snakehead
  • 1074 Answers
SOURCE: TV in standby mode
Hi iducher the tv power supply is faulty have a tech repair your tv.good luck
Posted on Apr 26, 2007
freetek
  • 5568 Answers
SOURCE: looking for power cord
That isn't a 'power cord' but rather an adaptor since it supplies DC power from an AC source.
Since you did not include the brand name and model of the monitor, you won't get much help here. I suggest you find that information and then go directly to the manufacturer's website to look for a replacement.
Posted on Oct 15, 2008
SOURCE: MISSPLACED AC POWER SUPLY FOR "MY BOOK" 250 GB USB.
THE ANSWER TO MY QUESTION WAS FOUND OUT BY MYSELF BY VISITING A REPAIR / SERVICE DEPARTMENT AND MAKING ENQUIRIES CONCERNING THE DC OUTPUT OF THE AC ADAPTER ASSOCIATED WITH THE WESTERN DIGITAL, MY BOOK 250GB USB. tHE VOLTAGES ARE THESE. : - AC INPUT = 100 - 240 VOLTS 50/60 HZ
DC OUTPUT = 12 VOLTS ( REGULATED ) 2 - 0 A
CENTER PIN OF 12 VOLT DC INPUT PLUG IS " POSITIVE "
THANK YOU FOR THE SPACE TO ASK MY QUESTION.
Posted on Feb 19, 2009
  • 22 Answers
SOURCE: AC Power Supply for Metz 45 ct5
Hi daf4,
I have a circuit diagram for the 45CT-5 and the flash unit as well. The voltage is 360V DC, which goes straight across the flash tube. The top pin is positive, when the notch in the socket is on the right hand side, i.e. towards the back of the flash.
I'm also looking for a circuit diagram for a 45CL-4, if you know anyone who has one.
Regards,
Neil
Posted on Feb 28, 2009
  • 7 Answers
SOURCE: Dell NPS-210AB power supply starts up then shuts off
hello bob, try putting a phanton loa on the other bars of the power supply, it seems tha the power supply is not starting, some switchin power supply require an apropiate load to start.
Posted on Jun 29, 2009
Power connector pinout for CT-13R50 television
Directly from the user manual, Page 5 under "AC/DC Power Sources":
DC Models ONLY
"This TV model operates on both standard household current (120 volt, 60 Hz AC) and car battery (12 volt negative ground DC) through the cigarette lighter. An AC power cord and a car cigarette lighter adapter cord are supplied.
Household Installation
Insert the AC power cord into the connection on the rear of the TV. Connect the two pronged plug into an AC outlet (120 volt, 60Hz). If you are unable to insert the plug fully into the wall outlet, try reversing it. If the plug does not fit, contact an electrician. Do not force the plug or defeat the safety purpose of the polarized plug."
The manual goes on to describe the vehicle installation which is identical to the household, with the only difference being the car plug goes into the DC side of the power connections at the back.
There are several kinds of power cord available for older TV models. Unfortunately, after an exhaustive search, I was not able to locate a photo of the back of that model television.
However, I have included three of the typical US power connectors found on a great many devices and in the majority of cases, one of these cords will likely be the one you need. They can be found at most local stores such as Wal-Mart, or can be ordered online from Amazon. Also, the cored generally only fit in one direction, especially if the cord happens to be polarized (thin blade and wide blade).
I hope this helps!
Panasonic CT 13R50 Manuals and User Guides
Apr 18, 2017 | Televison & Video
Can I use a 12 volt DC power supply with the Meade 4504 scope? I have a missing battery pack...and the input power says 15 volts Mant thanks
Yes you can just make sure that the power cord has the CORRECT pin polarity- you can order the 12 volt cigarette lighter style cord from Meade.
http://www.meade.com/support/index.html
Jun 27, 2011 | Meade 114EQDH4 (36 x 114mm) Telescope
Craig High Definition LCD TV (15.6 in) power cord
The power source is a 12 volt transformer so you can use a standard universal power supply. A 12 volt DC Power Cord with Auto Cigarette Lighter type Adapter will work in an auto.
Nov 03, 2009 | Televison & Video
Sound but no picture. menus work.
I had the same problem. In the menu, the image button was grey, and could not be hi-lighted, and the screen stayed blue. I was using the AC power cord. I plugged in the DC power cord instead, and it "woke" the unit up. I switched back to the AC power and it works fine. If you don't hve the DC cord that came with the TV, try andy 12 volt dc output cord with a positive tip.
Jul 12, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
Feb 18, 2009 | Western Digital My Book Essential Edition...
13" sansui AC/DC 12 volt use
Did you check the fuse inside the plug on the 12volt cord?
Feb 01, 2009 | Sansui COM312AD 13" TV/VCR Combo
Connecting intec gamecube screen
The Intec Gamecube screen requires both a 12 volt DC input and the AV input. The larger connection is the AV cable which plugs into the back of the Gamecube console. The smaller round cable is the 12 volt DC input cable that goes to the power source for your screen. The solution is to either get the original splitter cable that splits the DC power to the screen and the Gamecube, or use separate 12 v DC inputs for each device. These original Intec splitter cables are rare and are not cheap, and the only place I have found them for sale is at the NES Repair Shop:
http://nesrepairshop.com/online_shopping/index.php?productID=645
The only other solution is having separate 12 v input cables for the screen and the Gamecube. And finding the right size (very small) is also a task.
Jan 14, 2009 | Nintendo GameCube Console
I DON'T GET A AC POWER CORD JUST THE DC FOR MY VAN.
I'm looking for that TV For my van..we had same tv and now it doesn't work. How much would you sell it for?
Thank you
Mar 30, 2008 | Audiovox AVT1498 TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
